hey guys,
new around here, and relatively new to nissans.
i searched the forums, but couldnt really find anything that relates to this topic.
i recently bought an R32 off a mate who had it converted from gts to gtst, so changed whole engine, ecu, looms and whatnot.
the tacho has never worked since i bought it, and im damned if i can work out why, have tried the 10k resistor trick between pin 7 & 49 on the ecu, still no reading from the tach signal wire, trying to install aftermarket tach.
i noticed pin 7 from the ecu splices off in to two wires about 100mm after ecu, dont know if its meant to?
any pointers as to what i can try?
https://www.sau.com.au/forums/topic/404231-r32-rb20-tacho-problem/
