Guys,
Have Just finished painting and re assembling Cam Covers/ Rocker covers ect ect.
Got new CAS collars and Rubber grommet and reinstalled and kicked it over. Started good.
The CAS was put back in original position so bolts in the centre (Took Photos Prior to Disassembly) on all 3.
Thought i would check the timing so went out bought a Timing light.
1st Go : (Disconnected AAC valve or whatever its called under Plenum)
Hooked timing light up to battery and the other end to the 2 Black wires on the First coil/Spark Plug closest to Cam Gears.
Checked the marks on the Balancer and they were no where to be seen! (You Could Just make out the 30 Degree mark!) Probably like sitting 60+ if there was a mark! Turned of!
2nd Go : Loosened CAS and adjusted Clockwise bout half the distance. Getting Closer.
3rd Go : Fully Clockwise and its pretty spot on 20 Deg.
Bit of history. Car had a Timing belt/water pump ect (100K service) end of 2009. SInce that service I've put 75 klm ( yes only that much!) on it over 2 yrs!
Did the mechanic adjust it wrong or cam belt/gears put on wrong or something???
I have Power FC and its saying its at 20 Degrees at idle but prior to change it still said it was 20 so it must just adjust itself?
https://www.sau.com.au/forums/topic/404249-rb-26-timing-questions/
PowerFC assumes 20 degrees, it has no way of confirming (since cam timing is mechanical not electrical) what the base timing currently is set to.
What could have happened was the mechanic wrongly used 15 degrees (RB25s) instead of 20 degrees (RB26s) when setting the cam timing, and made things worse by using the wire loop at the back of the engine with a cheap timing light.
If you have to fully set the CAS to one side to get it even close to the desired base timing, then you have a tooth out somewhere.
I have yet to see anyone put a bloody timing belt on properly these days.
Mechanics don't give a shit, they just slap the belts on, tooth out or not. They don't care, because when you get it back, you pay them and that's all they want. As long as you can drive away, they don't give a shit of the job is done properly or not.
What two black wires are you referring to? There is only one trigger wire per coil.
Try using the loop down to the back of the engine, and if you still get a high reading turn around the pick up of the timing light other way around in the loop. If you are using the trigger wire for no. 1 at the coil, again turn around the pick up of the timing light the other way around if its reading too high.
If all fails, get a ignition lead and put it from coil pack 1 to plug and put the pick up around that.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
