Hey guys,
I'd just like to get a little feedback about a project that I and a few colleagues are taking part in.
Basically it's about creating an option for RB26 projects when it comes to high HP single or even twin turbo applications. Instead of boring the original RB26 block to accommodate 2.7, 2.8, 3.0 or even 3.15L stroker kits and potentially weakening the block, we thought a different block all together might be in order.
The project is a cast iron Nissan RD28 diesel block which just so happens to line up quite nicely with an RB26 head after only a little modification. Thus making an instant 2.8L block without sacrificing cylinder wall thickness i.e. block strength.
As you might be able to see from the photos, the oil gallery wall thickness and the cylinder wall thickness or almost exactly the same with plenty of 'meat on the bone' for larger capacity i.e. 3.2L with the appropriate stroker kit.
In short, this means a very strong cast iron block with no need to fill in some of the oil galleries like you would on an RB26 in order to insure block reliability. This means more cooling/lube for the internals by keeping the all the galleries open,
This block has been line boarded and has a custom Spool mains + plate. As you can see, the setup can obviously handle quite high HP applications and with the appropriate counter-balancing; see the better part of 10000rpm all day if needed.
Its a viable option for anyone considering a higher capacity rebuild with very little boring required if at all.
Certainly poses a better solution to dusting off an old RB30E and hoping for the best lol.
Anyway, I'll let the photos do the talking....
Please PM me any feedback or questions you may have guys and I'll answer them as best I can.
Cheers and enjoy.
  • Thanks 1
https://www.sau.com.au/forums/topic/404260-rd28-development/
Yes, I do apologize for that, I've seen a few too many split on the dyno so I'm a little dirty with regards to them. Each to there own I know and that was just my take on it. Not aiming to offend.
Hardly think your "dusting off an old RB30E and hoping for the best" comment is warranted.
Been done multiple times before, there's even references in the RB30 section to people doing it. There was even some reasoning as to why the RB30 was a better choice but I can't remember them because even at 3.2L... Not enough displacement...
Remember reading this as well.
What's the difference in the height of the block? I'd love some extra displacement, but don't have the room for the 30mm or so than an RB30 would add.
This could be a cheaper option than over $5k for the Spool RB28 kit, or $8k for the Tomei kit!
I'll get back to you about that one.
Yes there is a build in the works but this one in particular uses a 2.8L Nissan Diesel block with the intention to use a 3.2L stroker kit.
If it generates enough interest I'll make a build thread in the appropriate section.
don't expect to get away with anything like this for under 5K
First up, you're going to want to rebuild it anyway, then changes in inlet piping, exhaust, radiator etc etc,
Add on top a retune... its going to be exxy...
Also 40kg heavier is the mention of it over an rb30.
I'll pass for a street car... much better engine choices out there for cheap displacement in a skyline
Yeah, this was really meant to be a solution to block degradation post stroker enhancements to achieve a 3L+ displacement.
More designed for people looking at the 800HP+ area. I think a street car application would be pushing the limits of legality and practicality.
Not unachievable though.....just over kill for street use. The cost is a turn off at the moment but I believe that will change with time, although if your looking for cheap power, the last place you would look is a GTR build. That has at least remained constant over the years.
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
