Hi Guys,
Thinking of repainting my Black V35. Thinking of sticking on to the black but would like some suggestions of better colour options(with photos if you have). Also what are the questions that i should be asking like what type of paint should i use and other info. Could someone give me rough price for the job.
Thanks a lot guys.
https://www.sau.com.au/forums/topic/404273-v35-repaint-tips-and-suggestions/
  • 1 month later...
hey guys, few questions....cheap and best place to buy the paint in Brisbane...or do you think i shud order online....secondly is clear coat optional and do i need to buy some premium thinner for the paint...
buy the paint online? you are not going to try and paint it your self right? and clear coat, of course !!!!
$2500 or more for a respray from someone cheap..
$2500?! Would have thought that $4k would be a more appropriate number - for a decent job with proper clear applied that is.
Agreed, I had the turret (hood), and boot lid resprayed in another car a few years back now, and that was $900 - wasn't triple layer pearl paint either.. You can probably add 50% more if you want a pearl coat.
$2K would probably only get u a taxi paint job. i.e.: door jams, engine bay etc untouched. A proper paint full respray would cost you $5K++++++
so true i.e Sheldon's ._.
i would recommend just go BLACK so just in case unseen accidents color matching will be a breeze
i got a mate that goes car wrap pm me i can give more info on facebook
f**k off, my paint job is awesome - 3 layer pearl for 2k (Usually he does it for 4k - 5k). Not painting inside the doors / engine pay isn't the biggest deal, my cars white, inside my doors are an off white - in no way is my paint job a "Taxi paint job"
Even if I had 5k to spend i'd still rather spend 2k to get what i've done. I would change nothing about my car.
Edited by sheldon2369
Black is one of the worst colours to go with, although it does look amazing on most cars. Attracts heat and if you live in 25-30 degree heat every day you don't will suffer.
Scratches come up horribly and is very difficult to maintain, but if you take care of it and don't mind the extra heat then it can turn out being a very good investment.
You haven't changed colour mate. Pearl white on white is a pretty breezy job - compared to changing the colour all together.
Ever seen those cabs that are orange outside and inside is all blue still.. lol!
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
