Please need help from the car audio experts.
if my amp only allows 1ohm and 2ohm connection can i connect a 4 ohm sub? what will happen if i do?
For example,
If your amp is rated for 600w at 2Ohm then your 4Ohm sub will see only 300w.
If you connect a 2Ohm sub you'll get the full 600 watts.
If you connect two 2 ohm subs in parrallel (1 Ohm) you'll get 1200 watts provided the amp will load down that low.
If you load down the amp below it's lowest rating it will just go into protection and shut down. Do this continueously and it'll go POP.
