Hi guy please help me with this.
Below is a pic of the power fc i just installed in my r33, the power fc was reset back to factory, then i plugged it in and did the 10 minute idle, then the 10 minute aircon idle etc so that it could self learn before i take it to a tuner. The pic is of the sensors and the 4 with the black dots indicate a problem and the check engine light is on. please note that if i plug the factory ecu in the check engine light is off and the car works fine. It drives ok with the power fc in too but what do these sensor problems mean? are they related? the car is in tip top shape 97 s2 with 90 000 k's, stock turbo, fmic, forged internals, exhaust and intake are the current mods.
https://www.sau.com.au/forums/topic/404281-power-fc-help-on-r33-gts-t/
Yea i have already done that., just can't understand what the problems are Ignition..... car is working fine and f/p sensor which is fuel pump what the hell, and why is check engine light on? and ECC? what do i do to fix this, but apart from that the car runs great on the pfc just needs a tune.
ignition is fine...I'm pretty sure that is normal. Turn your ac on and see what happens. Turn your power steering and see what happens to that sensor screen. Might help you understand it a bit more.
Not sure what the WRN is though.
There is no problem....The dot by these items just shows that they are activated, as mentioned above,just turn the steering and you would see a dot appear by STR.
Only when a sensor is bad/ out of range the back ground of the value will be highlighted as can be seen with BOST, and this is because you have the boost control kit on.Go to etc. menu and select the character that has a + sign in it to turn it off. The WRN indicates the engine check light is on, again because of the boost kit.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
