Hey i have some after market parts for sale for a R34;
Shipping available for the smaller items at buyers cost im located in rouse hill,nsw
Greddy plenum - 800
Blitz inter cooler with custom piping - 300
Gates racing radiator hoses top/bottom - 50
Koyo twin core radiator - 400
Gcg hi mount exhaust manifold ex gate - 600
Splitfire coil packs - 450
Garret gt35r ar70 - 750
Strut brace front - 50
Nissan sports front bar with indicator lights - 350 - Rear bar available too
R34 xenon headlights with ballast ( original) - 700
Z32 airflow meter - 200
Apexi gt exhaust with cat - 500
Apexi gt front down pipe - 200
Apexi pod filter - 20
R34 Gtt front guards with indicator lights - 300
hypertune 90mm throttle body with tps - 300
Cusco brake master cylinder stopper- 60
Sard racing fuel rail twin entry - 250
R34 Bonnet with latches - 300
post-441-0-18262300-1341787470_thumb.gifpost-441-0-51805600-1341787504_thumb.jpgpost-441-0-79982700-1341787542_thumb.jpgpost-441-0-96507600-1341787579_thumb.jpgpost-441-0-98353900-1341787616_thumb.jpgpost-441-0-17541400-1341787788_thumb.jpgpost-441-0-61217000-1341787803_thumb.jpgpost-441-0-12378100-1341787818_thumb.jpgpost-441-0-00006100-1341787832_thumb.jpgpost-441-0-63633500-1341787844_thumb.gifpost-441-0-65049000-1341787932_thumb.jpgpost-441-0-74666100-1341787971_thumb.jpgpost-441-0-70050200-1341788009_thumb.jpgpost-441-0-51109300-1341788045_thumb.jpgpost-441-0-23185900-1341788082_thumb.jpgpost-441-0-32670200-1341788117_thumb.jpgpost-441-0-47225100-1341788130_thumb.jpgpost-441-0-00337000-1341788143_thumb.jpgpost-441-0-41601600-1341788158_thumb.jpgpost-441-0-29385300-1341788170_thumb.jpgpost-441-0-35330600-1341788236_thumb.jpgpost-441-0-97775800-1341788274_thumb.jpgpost-441-0-82816700-1341788313_thumb.jpgpost-441-0-89885800-1341788347_thumb.jpgpost-441-0-75560200-1341788379_thumb.jpgpost-441-0-36633100-1341788418_thumb.jpgpost-441-0-09068900-1341788446_thumb.jpgpost-441-0-77700500-1341788458_thumb.jpgpost-441-0-01722800-1341788473_thumb.jpgpost-441-0-09015700-1341788485_thumb.jpgpost-441-0-09938000-1341788531_thumb.jpgpost-441-0-75256500-1341788569_thumb.jpgpost-441-0-44073900-1341788604_thumb.jpg
I work during the day so pm or reply and ill ge back to you in the evening
Cheers
What condition are the headlights in?
From the photos they look pretty good, are there any marks, scratches, hazing, yellowing, cracks, etc?
NO marks, scratches, hazing , yellowing or cracks what you see is what you get!
Edited by infected flow
hey mate with the airflow meter does it come with the r34 adapter thingy
yep ill find it if you like!
u mean the plug right..?
    • I'd say the easiest way is, pick up a extended and baffled sump with fittings already welded on. Here is an example, it has 3 x -10 fittings  https://shop.maatouksracing.com.au/products/rb-extended-and-baffled-sump
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
