Panasonic Lumix G1 Micro Four-Thirds DSLR.
Condition is very well used hence the cheaper price.
Comes with a manual Canon 50mm F1.8 FD lens on a FD to M4/3 adapter ring (this is worth about $100 itself).
Lumix kit lenses are relatively cheap. Seen them go on Ebay for less than $100 but you can use any Micro Four-Thirds lens on the G1 body or any FD lenses with the adapter.
Great for learning how to use a DSLR before splashing on those ultra expensive setups. I'm still learning but need the $$ to fund a new lens for my other camera.
Comes complete in box with all manuals, cables, shoulder strap and charger. I've replaced the battery recently with genuine Panasonic item, so it holds charge like new.
Price $200.
Pick up Sydney (Marsfield area).
Edited by gel
