I have 5kg all in sperate 1Kg sealed bags,
Great WPC ive over ordered,
I drink these in water only and they mix great, Anyone in the game will know these are a great aussie product
PM for details.
$30 a KG and i will post for free
https://www.sau.com.au/forums/topic/404318-bulk-nutrients-wpc/
Yer i buy the unflavoured for the missus as she cant stand the faske sweetner aftertaste, TBH i much prefer the unfloavoured as its so much more usable in cooking ect.
Either way, BN are great huh. Support local and its better then all the expensive crap on the market.
unflavoured is best as you can whack it in certain recipes, if you want flavour you can add diet toppings or on post WO just use normal toppings. I mix it in with my bedtime yogurt ect. Not every protein shake has to be a flavour sensation ;)
fair enough, just paid the extra $20 for banana, a bit too sweet but it mixes better than my optimum nutrition, thought i couldn't give it up after 4 years, so glad i decided to bite the bullet and try bulk nutrition
