hey guys i really need some help sourcing this problem becuase i have now run out of ideas.
rb20det
boche 044
standard injectors
kkr430
turbo tech 16 psi
microtech ecu
fmic
3" exhuast
new copper plugs gapped .8
ill start from the begining, when my car first started miss firing i found out that the fuel filter was block full of brown shit and the tank had water in it, i put a new filter in and cleaned out the tank and put injector cleaner with a clean full tank of fuel.
it was still miss firing after i used that tank of fuel.
so i bought some new plugs and i borrowed my mates standard injectors and coilpacks which i new were fine, installed plugs, injectors, coilpacks and cleaned the fuel rail because there was a little bit of brown gunk which was clean up any way it was still miss firing at high revs.
i have noticed if i dont hold the accelerater flat it doesnt play up.
https://www.sau.com.au/forums/topic/404323-rb20-missing-at-high-revs/
Did you change the fuel filter again? I would be cleaning the lines and tank completely then drying the lines with compressed air.
The injectors have a filter in the rail end, perhaps these are blocked? Don't keep stomping on it to test, its probably running lean.
yea i replaced the filter again, ill take the fuel rail out and give it a good clean and look over. is the fliter in the rail in each injecter slot?
cant really lower boost can i ? its tuned to this psi.? but ill also try a compression test.
there is a mesh screen at the tail of each injector, the only way to clean the injector and the screen correctly is to backflush OR you can buy new screens but they can be a bitch to change
ok so i found out why there was heaps of water in my tank, the fuel tank breather was facing behind the back wheel so when it was raining the tank filled up with water.
so i pulled the tank out and cleaned it properly and blew the fuel lines out and the fuel rail, and replaced the fuel filter and relocted the fuel tank breather line. after all this done it definatly went better but is still missing up at high rpm,
bought new ngk copper plugs, gapped to .8 and also tried running lower boost still missing up high, is there any way of testing the fuel pump myself or easier to to get it on a dyno?
Just hook up a fuel pressure guage to ur lines after the filter and before the rail and take it for a little drive and see what its doing.... Someone here will know what pressure it should be at idle and through the revs etc. Also depending on what pump u can flow test it aswell to see if its up to scratch. Failing that go to a dyno day.... 50 bucks and the tuner will give u an idea of what may b wrong.
Edited by FordyR31
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
