hey guys i really need some help sourcing this problem becuase i have now run out of ideas.
rb20det
boche 044
standard injectors
kkr430
turbo tech 16 psi
microtech ecu
fmic
3" exhuast
new copper plugs gapped .8
ill start from the begining, when my car first started miss firing i found out that the fuel filter was block full of brown shit and the tank had water in it, i put a new filter in and cleaned out the tank and put injector cleaner with a clean full tank of fuel.
it was still miss firing after i used that tank of fuel.
so i bought some new plugs and i borrowed my mates standard injectors and coilpacks which i new were fine, installed plugs, injectors, coilpacks and cleaned the fuel rail because there was a little bit of brown gunk which was clean up any way it was still miss firing at high revs.
i have noticed if i dont hold the accelerater flat it doesnt play up.
https://www.sau.com.au/forums/topic/404323-rb20-missing-at-high-revs/
Did you change the fuel filter again? I would be cleaning the lines and tank completely then drying the lines with compressed air.
The injectors have a filter in the rail end, perhaps these are blocked? Don't keep stomping on it to test, its probably running lean.
yea i replaced the filter again, ill take the fuel rail out and give it a good clean and look over. is the fliter in the rail in each injecter slot?
cant really lower boost can i ? its tuned to this psi.? but ill also try a compression test.
there is a mesh screen at the tail of each injector, the only way to clean the injector and the screen correctly is to backflush OR you can buy new screens but they can be a bitch to change
ok so i found out why there was heaps of water in my tank, the fuel tank breather was facing behind the back wheel so when it was raining the tank filled up with water.
so i pulled the tank out and cleaned it properly and blew the fuel lines out and the fuel rail, and replaced the fuel filter and relocted the fuel tank breather line. after all this done it definatly went better but is still missing up at high rpm,
bought new ngk copper plugs, gapped to .8 and also tried running lower boost still missing up high, is there any way of testing the fuel pump myself or easier to to get it on a dyno?
Just hook up a fuel pressure guage to ur lines after the filter and before the rail and take it for a little drive and see what its doing.... Someone here will know what pressure it should be at idle and through the revs etc. Also depending on what pump u can flow test it aswell to see if its up to scratch. Failing that go to a dyno day.... 50 bucks and the tuner will give u an idea of what may b wrong.
Edited by FordyR31
    • Dredgggggeeee time; I have recently finally started driving the car. It sat for so long that the fuel tank gave birth to rust sludge and blocked my lift pump sock and one of my walbro 460's and left grime, rust chunks and muck all through the surge tank and system. I decided to commit and pull the trigger on an oem r32 gtr fuel tank and Frenchys twin 460 / sender / surge tank hanger combo and all new larger lines and fittings etc, also boost doc heater hose kit / new heater core and a heap of other bits and shits like wideband sensor installed in the dump and Syltech iacv + lines and all wired and added to current tune. now having lightly driven it a couple times without issue, I can happily report on the hta3076 in its current tune. still no boost control switched on, 20psi gate springs, car makes 22psi at 3200rpm in 6th gear with 30-50% TPS from cruise at 100kmh. Going by the old graph, this means it should be making 300-325whp at the same numbers above. Very very responsive setup under true road driving loads. all that's left for the build is body loom + PDM, finish the remote aircon setup, install carbon fibre parts and go for full tune and 30psi. the 315 rear tyres are now performing like they're 195's, wheel spin in any gear at almost any rpm, whereas my previous setup hooked up in 3rd no issue, albeit Nt01's back then / RB25 5spd vs (new) old date r888r's Z34 6spd now, + obviously all the support upgrades I listed in the quoted post above. car sits at 1-3psi on cruise at 100kmh, expectations totally exceeded and I'm beyond stoked with all this so far. IMG_4848.mov
    • I've also been eyeing their rear axles for my car. I purchased seat mounts from them about 7 years ago and they were hot garbage so I've been a little wary about purchasing them. With that being said, please buy them and get back to us haha.
    • Can a moderator please move this into the right category.. I've accidently put this into racing build thread 🤦🏽‍♂️
    • Being a manual, we very quickly ordered new R34 gearbox (From Nissan) and remaining parts from Kudos motorsports. Would highly recommend the team there. Ultra helpful and quick to share advice and upgrades. We are in the middle of taking the Auto out (Genuine 94,000/kms) and putting the Manual in this weekend. Part 2 of the build will include likely a Plazaman Intercooler and Plenium, Hks Exhaust with Tomei Dump (ordered).
