I'm really not sure on car sound systems, I want to get these 3 products but not sure if they are worth there money, can I need someone to shed some light and help me out.
Head Unit: http://www.alpine.com.au/showItem.php?item_id=186
Speakers: http://www.alpine.com.au/showItem.php?item_id=83
Subwoofer x2: http://www.alpine.com.au/showItem.php?item_id=104
Amplifier: http://www.alpine.com.au/showItem.php?item_id=173
Is there a better set up I can get for that price, if so. What, and if people have this setup or have some of these parts let me know there performance. On another note, would they all work together flawlessly?
https://www.sau.com.au/forums/topic/404328-alpine-sound-system/
Depends on how its wired
What car its going into
What is your goal ? Enter contest, show system, just loud , clear , etc
Your music source needs and type of music you listen to
Dont forget wiring and install costs
Sound-deadener for at least the doors in this range of equipment
Charging system of the car , wiring and battery not up to snuff or old as dirt , even class D amps gulp power and a 30 dollar add water jap battery will last a few weeks tops and has poor connectors
Radio is fine for double din opening
Splits are good but overpriced
Subs are good but not my first choice for the cash
Amp is mono so wont run the splits which leaves deck power on those , which would be a huge fail
On type x splits unless your planning a second amp later on to run those ?
I love alpine gear but its not the first choice for everything and if your on a tight budget look elsewhere or do it in stages
Kiss most of your boot goodbye unless you get creative on box for subs in a coupe
really you need to do the shopping and listening
To fit goals , car and budget
You could do a 500 dollar system or 30,000 dollar system , but sound similar if installed wrong
Bump answer the questions above for a more detailed answer
It could work but not optimum and there are much cheaper options even in the alpine brand
What I'm asking is, all that together do you think it's worth it?
The car will be used for personal use, and for parties, Needs to be really really really really really loud. For hardstyle and stuff.
It'll be going into a Nissan Skyline GT-V R34 1998-2000 Model.
Edited by Skylow
Hmmm no it wont be really really loud or clear !! really loud to me is 150+ db and that wont get you anywhere near that 125-30 if your lucky and its buillt right
For parties WTF !! , no
When your serious then talk , your not even in the ballpark for SPL
