Hey guys thought I'd see if anyone in Canberra wants this stuff before I put it up in the for sale section. Now that I've sold my GTR I don't need this stuff anymore.
N1 rb26 block. Will need a clean up. Was part of my engine when it spun a bearing. I haven't had it checked out since it was pulled apart in December last year. Was planning on reusing it but sold the car without it. So am unsure of exactly what condition it's in. Had just over 25,000kms on it. Will let it go for $500.
Rb26 head with everything except cams, cam gears and cam, cam gear covers. Part of the same engine as the block so planned on reusing it also. Had been reconditioned. Still has intake and exhaust manifolds attached. Chasing $500 also.
Grex cams. Can get exact specs if you'd like. All I know is that they don't make these anymore. We're again part of the same engine. Will be happy with $250 for them.
Rb26 sump/diff with tomei baffle $150
R33 rb26 crankshaft. Was brand new when engine was built so only done about 25,000kms. As the engine spun a bearing it will need a clean up, haven't had it checked out so unsure of exact condition. $200
Probably have a few random little rb26 bits as well so if you need anything just ask. Am hopefully going to be taking photos on my day off on Wednesday. Any questions just pm me or SMS me as I work pretty long hours so will call you back as soon as I can :)
Cheers guys,
Drew 0433414424 :D
https://www.sau.com.au/forums/topic/404346-rb26-block-head-and-bits-for-sale/
  • 1 month later...
hey I'm keen on the head if its not sold yet? Its for an RB30 im building at the moment all i have is the block and sump so need all the covers and that too!
Hey mate, sorry you just missed out. Sold the complete head to a mate at work last week.
Only think I really have left now is the r33 crank
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
