My r32 gtr Has a custom catch can where my battery was ( battery's been relocated to boot)
Now when I got the car the engine had the PCV valve blocked, inlet pipe on rear turbo blocked, and basically had 2 hoses from the cam covers going to the can, which was vented to atmo
I don't want this running to atmo anymore,
My question is: can I run a hose from the catch can where it vented to atmo, back to the rear turbo inlet so it "recycles" the crankcase fumes ?
Still keep the pcv blocked?
Have searched but didn't get exactly what I'm after
Thanks
https://www.sau.com.au/forums/topic/404368-rb26-catch-can-and-pcv/
I think you will need the PCV connected. As at idle i dont think it will pull enough pressure/vapour out of the head.
You could just get one of those little tiny catch cans and run a seperate one for the PCV. Problem solved then :)
I had the same setup as you mentioned, and i got blowby at idle with the PCV blocked. So put it back in and problem was solved.
  • Like 1
+1
I run a similar setup, pcv plumbed into small sealed catch can then to the manifold and the main breather to catch then back to the intake. Both catch cans will need stainless steel wool inside them or they will dump oil fumes into the intake still.
I also setup two ball valves and some hose underneath them to make draining easy.
  • Like 1
still not 100% clear as to why having the breather hose in the rear turbo intake, with the PCV valve closed wont work....but atmo it will ?
when the engine is on, isnt there always gonna be vacuum in the turbo inlets? i mean the engine needs to suck air to work right?
at idle/vacuum air will draw from the the driver side breather port through the pcv (one way valve) into the intake manifold.
Any time when you start making boost, the pcv will block and no air will draw into the intake manifold. Air is sucking through the passenger side breather to the the rear turbo intake.
I think in a idle/vacuum case the pcv side has higher pressure drawing in, and the turbo side isn't doing much. Plumb your can inline with the turbo side and reconnect your pcv like stock. Or plumb both sides up into one can, or run two cans alternatively. The turbo side will pick up all the oily fumes on boost. The pcv side only picks up oily fumes during vacuum situation.
here is the right way to plumb your can, every other way is probably incorrect
http://www.skylinesaustralia.com/forums/topic/40402-greddy-oil-catch-can/page__st__60__p__1179419#entry1179419
  • Thanks 1
There are unlimited ways to plumb catch cans and some are much better than those ways you linked. Personally I would never vent a can to atmosphere, or drain the oil back, but each design has its merits I guess.
If you have oil filling the can you have much bigger issues, they should only be used to control the oil vapour and stop it lowering your combustion octane, or to stop oil condensation in the cooler and manifold imo.
when i got pulled over into a defect station last week, the EPA inspector told me instead of running it ATMO to just run a hose from the breather on the catch can around to the air filters so they suck the fumes.....dunno if this is the "legal way" or not ?
but he also told me to put a cover over my pods....but i know that wont pass when i go to clear my defects :/
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
