The President is also (IMHO) one of the worst styled luxury cars money can buy. Truly awful :D
Celsiors are nice, with a sensible kit and decent wheels. Trouble is, more often than not they end up with some monster kit, wing's bigger than most planes, drainpipes...no sewage pipes for exhausts and massive wheels at a ridiculous camber angle squeezed under monster fenders....:)
https://www.sau.com.au/forums/topic/40443-vip/#findComment-832788
uh no...:D
VIP strickly speaking mostly sedans and vans which enables you to fit a bigass sound system and still have your mates in the back to cruise around with you. Not to mention it's suppose to be a slug, heavy and with very little performance thus it's a show car. Which is the reason for it's popularity with bitumen scrapping bodykits but they seem to think they can still drift the car which results in an even better bodykit, one with a damaged/torn front bar...mostly entered in SPL comps.
https://www.sau.com.au/forums/topic/40443-vip/#findComment-840014
Dave: now VIP vans is something I would consider myself...more practical, more space and looks so much more better then a sedan when dumped on 20". A van would be no heavier then a sedan, plus it has a greater sleeper effect...with a 4WD version and the fact they are now front engines tuners have been able to slap on S/C anc T/C for some mild boost. My choice a Hybrid Estima, black of course, 20" with a nice kit :), the guy who installed my alarm had his new demo white Alphard at the shop...very very nice. Because it was a shop demo car it had every freaking alarm possible and security devices install on the market to demonstration to the customer. He joked if this van could be stolen via means of entry the theif is a genius.
https://www.sau.com.au/forums/topic/40443-vip/#findComment-841169
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
    • Put a piece of tape on it.   If it's that gone, you would be seeing it on the balancer. It would look rooted. Not in this universe.
    • If you’re in Australia and need a one piece tail shaft give propeller shaft repairs in concord a call. They do all the big Sydney cars and they don’t vibrate at all don’t get one either cv joints, they bind and cause the vibrations
    • Want to change and monitor if it robs again   could be my harmonic balancer is gone   do you reckon it can be bent crank , don’t believe so at 600+ hp that would shop very quickly so can think either harmonic on way out or at somepoint in car life it wasn’t tightened so balancer wobbled
