Gday guys trying to trouble shoot, my alarm/immobiser.
The M80g has been fitted to run with my external HKS timer. If i dont use the timer or wait for it to turn off then it works properly (immobilises/alarms)
However i turn on the turbo timer, i get out it still runs and i can lock the doors and once the car has finished running it will turn off and immobilise but it wont arm the alarm, the remote doesnt beep.
As i didnt install it i dont know if its a feature i need to enable or its been wired wrong.
Cheers
Patrick
  On 10/07/2012 at 11:17 AM, Hadouken said:
read the booklet. I have the m60s and whil playing with it, mine locks and immobilises when turbo timer time has finished. Besides, its wank, just disable it.
Been reading the book, AND if you had a genuine Manual like i do you will find it actually says if you got 100kph to let the car idle for 30sec or if 100kph and slopes or +100kph to let the car idle for 1 minute.
  On 10/07/2012 at 11:36 AM, Hadouken said:
No need to get a big head about it. Its hard to sit in the car for 30 seconds
Cool story brosef, the immobilser has the ability to interface with an external timer, was after solution not your opinion, ttys xoxo
  • Like 1
So i guess my real question is, how do you programme the alarm to interface and arm with the external timer, the booklet i received and pdf i got off mongoose do not clarify this.
cheers
Okay problem SOLVED!
If you have a 2012 plus models does not with programming!
If it has been wired correctly donwloading the pdf directly from the mongoose website. Have the car locked and unlock it, with drivers door open quickly turn key in ignition 15 times "as fast as possible" and then turn back to ACC. Count the beeps to make sure you got 15, then if so press button one. Wait ten seconds for a three chirp confirmitory. Kick over car with timer on and try locking it holding down button one, if it locks with a beep you will have success!
Edited by Pattey21
  On 10/07/2012 at 6:11 PM, kylieyeah said:
Why would you run the HKS turbo timer when the M80G already has one. That's like noob step number 1.
you must know everything, ill come staight to you next time. Externals timers are more user friendly as you dont have to re-programme it everytime you want to change timer duration.
Cool story hansel. :P
I think people need to start realising that when you come on a forum that you will get mixed responses from vast community/background/age group of forum users.
But seriously, good for you figuring it out. So does it lock and re imobilise the engine when the timer has run out?
Have you sat in the car and tested it? Does the car switch off and imobilise when the door is opened while the timer is running?
haha. Yeah it works and arms properly now. Its stupid how the books doesnt include the programming from 2012 onwards. It mentions the features but advises to contact installer to do any.
it was removed for a reason. those units are sold in 3 countries and NZ did not want it in there.
I too remove T'timers. makes the car entirely too easy to steal.
and before you even think of giving me a serve do a search on who I am :)
Jebus?
your just a big D@#K head thats who you are......kidding.
Thats actually a really good point just bridge the igntion it at the timer plug and either roll start or tap into starter and your away. something ill have to think about
Is there something i can do to make it harder to steal besides hiding/ attempting to armour the wiring?
Edited by Pattey21
good at making friends aren't you :)
in short - piss the timer off and sit in the car for the extra 30 sec. 30 sec out of your life isn't going to hurt you.
mind you I could probably still take the car anyway. most people dont give a rats about alarm install so its probably very obvious and easily bypassed..
My mate who installed it is a electronics tech and before use to be in the trade of doing alarm installs so its proabably well hidden. However in saying that he neglected to tell me the issue of a timer compramising security.
Thanks for the info Chris i appreciate it
Edited by Pattey21
*Thread hijack
So would this mean that my security is compromised since my turbo timer (which I actually use as a boost gauge) is still in the car, Chris?
Or was there something done to the wiring to make it that much harder to steal?
Oh its my turn to shite shir haha Been a while
Your ghey turbo timer is a adr defect ( but I'm sure you dont care!) but it must time how long you wank off ...so the 30 seconds is enough to cool off ? or set for 1 min so the oil has time to cool off and not stick to your palms
But its good to know your master mind fixed it " gold star to you "
In the future ask questions with some respect to the ones trying to help you ffs or expect a ban stick off SAU
A lot of people on SAU have skills well beyond what you could even imagine and help people in need if asked polite !! instead they could say FU pay someone to fix it !!
So chill out
Even if you dont agree show some respect for your fellow sau members
End rant , waits for bitchfest so the ban stick can come out
The question is a nissan is a soft target ( crime in japan isnt rampant like here) multi layered approach to security and even a 10 buck club will slow them down and stop joy riders
Gps tracker is a must on any decent cars and even that isnt a magic fix
Common sense is one major prevention of theft
    • At least you're now aware of the problem and can come up with a solution.
    • Dang. Keen for further updates when you get to it.
    • Welcome to SAU Thomas, sounds like you'd had a bit of a an unlucky start with the car, hopefully you get some better luck now!
    • 1. No need, it only gets used once then is locked in place by the nut 2. EN-62 point 6 shows the conical washer the other way around (BTW I know we discussed above, I hope you are changing the idler as well, while it is no guarantee the bearing is a actually bad, it looks terrible) 3. I'm not really clear on the question, are you worried because it was easy, not hard, to remove the custom timing trigger? As long as it doesn't spin on the crank (when the bolt is tight) all good 4. Yeah just make sure the brand is easy to read as it rolls past 5. The part number is on the listing under the description, 13023-42L00. Given there is a custom part on there for timing (presumably outside the cover), they may have decided to leave that off; I think I would put the washer in there as it also helps seal the timing case from crap getting in.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
