Oh its my turn to shite shir haha Been a while
Your ghey turbo timer is a adr defect ( but I'm sure you dont care!) but it must time how long you wank off ...so the 30 seconds is enough to cool off ? or set for 1 min so the oil has time to cool off and not stick to your palms
But its good to know your master mind fixed it " gold star to you "
In the future ask questions with some respect to the ones trying to help you ffs or expect a ban stick off SAU
A lot of people on SAU have skills well beyond what you could even imagine and help people in need if asked polite !! instead they could say FU pay someone to fix it !!
So chill out
Even if you dont agree show some respect for your fellow sau members
End rant , waits for bitchfest so the ban stick can come out
The question is a nissan is a soft target ( crime in japan isnt rampant like here) multi layered approach to security and even a 10 buck club will slow them down and stop joy riders
Gps tracker is a must on any decent cars and even that isnt a magic fix
Common sense is one major prevention of theft
Exactly i couldn agree more show respect were respect is due. post count doesnt represent ones knowledge, stupid questions get stupid answers and stupid answers get snide remarks and this is all defined by the individual users intepretation, so go figure. Welcome to the internet my friend :-)
Thank you for listening , come again
Off topic
(Been on the net before it was called " the net " or before it was pc based ) and remember punch card mainframes at college lol
But the lack of respect and keyboard warriors flaming is from the past 10 years more so the last 5
Taking the piss is not the same as disrespect
Anyway its cool
*Thread hijack
So would this mean that my security is compromised since my turbo timer (which I actually use as a boost gauge) is still in the car, Chris?
Or was there something done to the wiring to make it that much harder to steal?
troy ,
lol :)
either of your will take a truck (or me) to move them.
  • 1 year later...
Now in all seriousness, I just brought a hks turbo timer with a plug and play harness. I though this would be very simple. I plugged it all in. And done the ground wire. All the modes and stuff come up and it seems fine. But when I turn the car off it does not count down and leave my car running for the time displayed. My car will run for 1 second after I turn it off. I have a mongoose alarm installed. It immobilised it self after 30 seconds of turning the car off. I'm still new to all of this. Can anyone tell me if I'm doing something wrong.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
