Hey, I've got a r33 na with an x-force cannon (4 1/2 inch) and want to get it quieter with less vibration that hurts your head after a while. I've installed the silencer and that's done alot but want to hear any ideas of fiberglass, cotton etc inside the cannon to get some quietness. Thanks
A Varex muffler would help, they are one of the best sound deadening mufflers I have found so far, and then you can close the flap to silence them if you need to. My 3.5 inch one doesn't drone much at all.
How did you set up the boost actuated Varex???
Does anyone in here have a car that can't be defected? At the end of the day the goal is to not be pulled over, the impression of a stock car is the key imo.
Unfortunately there are no aftermarket mufflers I can recommend to reduce noise to a legal level other than the closed Varex. Other than that you would be best off finding a S/H jap cat back with a Jasma label.
I have gone back to the Varex motor on mine as the varex valve was too tight and kept jamming. There are other options I am trying at the moment.
Exactly, I think even my FMIC can defected can't it, just don't fail the dick head test if you do get pulled over.
The boost controlled varex looks interesting, shame it didn't quite work, and am interesting in hearing what you come up with.
there are plenty. any exhaust shop could sell you about 10 different ones that would, but few people would want them on their imports as a: they aren't fully hektic cannons, and b: they aren't a straight through type (so don't flow as well). but even a decent flowing muffler used with a decent centre muffler will give you exhaust levels below the legal limit. a non performance orientated muffler will be built in the same way as a stock one and give the same level of noise attenuation
With a 3.5 inch system? You have to be kidding... Most of my customers want 300kw at least these days, with two free flowing mufflers. There aren't many on the market that cater for low noise along with the flow, especially in stainless.
    • Do the following first and get back to us. - Clean and verify your IACV - Verify for vacuum leaks/post MAF leaks. (Pressure test is the best and cheapest way) - Do you have a BOV with stock ecu/MAF? If so, remove it.
    • Hey all, The skyline I have is stalling when the engine is at normal operating temp.  When starting it while it is cold, it'll run just fine.  I have replaced the battery (bad cell), I have replaced the fuel pump, fuel filter and clean the MAF sensor.  Any other suggestions?
    • Thanks for all the information on this.  I tried ordering the parts from Amayama website and all 3 Solenoids are discontinued and not available.  Does anyone have any other websites to suggest that I could find the parts?   Separate issue-- I will start a new thread, but basically the vehicle is stalling when warmed up.
    • It's unfortunate what Tomei USA has done to Tomei's name in general. I'm very weary of ordering parts from them now. I only order direct from a Japanse source (e.g Nengun). At least their logos are different, so you end up knowing what you have.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
