Hey looking at selling my r32 as iv found another car i like and need the extra cash.
Iv had the car for 2 years now maybe getting driven 1-2 days a week just to the shops locally anyway, iv never taken it to the track and it drives pretty well! car has done just under 160k on the dash
Since iv owned it iv given it royal purple for the engine oil and used Nissan oil filters,
I had the 100k service done in feb this year (kit bought from kudosmotorsport) along with the following;
Rb25 turbo
R34 SMIC
JJR front pipe
42mm alloy radiator
Fuel Pump those warlbro ones
32 GTR brake all around with QFM hpx pads and Slotted rotors
And currently int he process of getting a new battery and drive belts!
Has a GTR boot with wing thats all i can think off'
r32 GTR wheels aswell!
Was taken to racepace not to long ago was tuned at 149.7kw
There are a couple bad points aswell
Steering wheel leather is gone but i have a Good condition stock replacement to give
and the boot lid would benefit from a spray its black already but not perfect i bought it like that and just put it on.
2-3 small dents on the rear quarter panel
will be giving rego till oct, but no rwc it should't have a problem getting one tho
Im looking at 8k as it is but am open to offers will do cheaper if you bring your own wheels or if you want stock one(with the rwc tyres)
Thanks for looking and Pm if your intrested.!
im in Melbourne South east side!
have posted a few pictures
https://www.sau.com.au/forums/topic/404467-r32-black-gtst-manual-vic/
  • 3 weeks later...
Bump
Have found out that exhaust manifold is leaking
I have the gasket already just needs to be put in
Car still drives fine :)
Will take 6k
Car is located in prahan if wares to be looked at
Okay so Log story short the exhuast manifold doesn't need to be changed it was the turbo gasket and it's been changed already lol
Will still let it go at 5.5k tho cause paint int 100%
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
