Yeh so they say. Its fkn massive! Ideally I would mount it close to the rail, but I can't see it fitting anywhere unless I remote mount the sensor and run like 2 meters of hose to it :/
on commodores it is mounted onto the fuel tank, so doesn't need to be close to the rail.
Edited by superben
Don't they run a single fuel line to the rail and no return from that point ?
A .
yes, late model crumpledores run a returnless fuel system
part of the reason is for a reduction in evaporative emissions
  • 1 month later...
As a matter of interest, is there a way to test ethanol blend fuels for water contamination? Say for example I have a few jerry cans of E85 sitting around for awhile, is there a way to test whether the fuel is still ok to use before I put it in my car? Or is it largely a game of pour it in and hope for the best?
Well I'd like to avoid a situation like Mat's, where he put a bad batch of fuel in and ended up needing a new set of injectors. Could have been worse if the Haltech hadn't shut things down, but I don't know if my ECU will be set up as comprehensively as Mat's. I don't actually know what went wrong with the batch of fuel he put in, but I just thought there might be a way of telling whether some water has got into the fuel before it goes into the car.
The same could be said about any fuel, many cars have filled from the bottom of the servo tank and blocked filters/injectors, or blown engines.
I have been running ethanol for 4-5 years daily without issue, if you want more of a guarantee, perhaps drum fuel is the go? Just make sure the lid stays on.
Some water in the mix won't cause any issues, it may run a little lean but don't you have a wideband going in?
I've just spent a couple of hours reading everything I can on the forum about ethanol.. Very interesting, many thanks for the input everyone. Especially with all the time people have put in testing ecu's, fuel content etc.
Few questions.. will keep it simple and brief.
1) From what I read, it seems as though the AFRs of ethanol are not as critical as 98. Is this the case? - My ecu is old but it seems that new injector technology helps a lot with fine tuning. Will mapping big injectors with 500rpm increments be a real issue? (Wolf V4)
2) I run a single 3/8th fuel line, will this be a limiting factor?
3) I run a Sard 1:1 Fuel pressure reg. Will this be a an issue?
4) Plan is to upgrade lift pump (Suggestions?), Swap the 044 for a 400lph Walbro with a filter before the lift and pressure pump, ID2000s or something big. Replace all fuel lines just for piece of mind, put it all together and take it to the dyno.
Any objections or suggestions?
Cheers all,
G
Anything not properly gal coated, such as the tank or steel lines, may rust out eventually due to moisture content. Generally e85 is pretty good as United/Caltex are required to mix corrosion inhibitors in the mix apparently.
Replace any old rubber lines with ethanol compatible new hose and stick a Walbro 460 in, you shouldn't have any issues with the reg.
I would stick with the bosch 1000's, or the ID 1300's if you can find a set.
As for AFR's, my car ran pretty well cruising on 20:1 other than feeling a bit doughy, no discernable knock and the exhaust temps were under control. Not saying it's smart to tune it that lean, but it's possible, unlike with 98. Good to know when an issue arises you have some level of protection.
Ok great, thanks.
Also, has anyone made the swap to E85 and not made a increase in power? I've been told that depending on the engine it may not really make a difference due to head not being able to flow etc.
In saying that, my FJ20 runs 291 degree cams with head porting and a GT3040. I'm pretty sure there is a lot more left in it....
If there is no increase in power on a turbo car then something is wrong. If the tuner is telling you that the heads ability to flow air is fine for pump gas but not E85 then consider my eye brow raised
well said! so I'll go ahead and get myself a bigger pump and injectors and get it to the dyno.. Already cracking chassis welds with 400hp in my bluebird. See what happens if it makes 500 haha.
Should go ahead with everything in about a month so I will do a step by step build guide to add to the thread for anyone interested.
Other than that, I looked up the Walbro 460. I believe that's an in tank pump. Anyone recommend a tried and tested in line?
If anyone has any other info from experience that I might benefit from, I would love to hear it.
Cheers.
Does it still have that hateful 4 link rear end with the diagonal top links ?
Semi trailing arm rear end from SSS 910/200BSSS/DR30 solves the problems but adds weight . Mine had the DR30 R200 stuff with a Nismo LSD - eventually .
H190 Detroit lockers make them open up the rear seams too .
A .
  • 2 months later...
if i established a flex fuel tune using Sucrogen E85 with 108octane. If I use Martini E85 116octane do i risk doing any damage. So far im thinking it will be good for reducing the likelihood of knock etc. But are there other hidden things that could potentially destroys the engine or anything else related to using high pure race octane.
Only asking because there's a workshop currently selling the Martini stuff at a good price.
any 85% ethanol fuel essentially means you do not have to worry about knock (with a half decent tuner), $ucrogen or whatever other overpriced E85 drum fuel isn't going to make much of a difference imo
just tune on United if available, or Caltex - the whole idea of flex is to change the mapping based on E%, not octane. ie, you don't have to worry.
Drum stuff is just not worth it... time attack... maybe, our cars.... nup.
i do understand how its all E% based, im getting the car steup for flex fuel. So if I did that with the Martini E85 im worried that if i use a lower octane fuel like Caltex or Sucrogen it will be like putting in 91octane when you have it tuned for 98. But if i use the Sucrogen stuff then an addition octane may not be a problem but im still not 100% sure. Im using the sucrogen mainly for the fact that its 100% just for the tunes sake, united in Canberra is shit they dont have E85 and at Caltex it was E77 a few days ago.
I think you may have misunderstood the definition of 'flex fuel'
The whole idea is to have a sensor that measures E% and the ECU adapts accordingly.
Running your car on ethanol and setting it up for flex fuel are two different things.
ok, use $uckrogen drum for base E85 tune - that's your pure 85% baseline, then 98 tune and however your tuner wants to work from there. I don't think it would make a difference using the Martini as your 85% reference if the tune is conservative. But given you won't be drum filling the car, use the other brand and whatever caltex gives you, caltex gives you.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
