I'm not sure the Haltech can do that. They can't do aftermarket trigger input from a hall effect sensor in their 'Pro' model or closed loop boost control over wheel speed so I'm pretty sure they wouldn't be able to handle something like that? Can anyone confirm?
I run PS2000 with full flex etc.... Haltech said it can't be done, JEM said it can and proved it :)
I am running Power FC with Data logit...f**k the massive expense of all the hardware, tuning etc with the systems explained above. For me this arrangement is fine as I drive like an old lady on the street and leave the full load, boost stuff for the track so pretty easy to manage the fuel side of things...95 on the street and E85 for the track
zackery
Also, the difference between 85% and 70% doesn't necessarily effect the octane rating as they can/do use other additives - not just 30% 91RON + 70% Ethanol
If your initial tune is done on 85%, even if you put E70 in, it's only going to run slightly richer....and depending on your tuner, that can be a good thing
zackery
thats what i wanna hear ... bring it on .. looking forward to getting an E flex tune...
Edited by SliverS2
Daniel by way of comparison between a pump 98 tune vs E85, what is a typical full-load target AFR? And what is a typical cruise/low load target AFR?
Also interested to get a handle on fuel system delivery requirements for sizing. ie. for a given power target what is the rule of thumb for injector sizing + pump(s) vs running on pump 98?
Rough sizing requirements on methanol were to expect double the fuel usage over avgas. The calorific content per unit of mass in those fuels is a factor of two so easy enough to understand. I would imagine the maths for ethanol would be roughly similar.
Ok so what were the target numbers to chase?
Appears that as a blended fuel the calorific content is bumped up a fair whack from straight alcohol. 30% differential at max power should see an 044 pump cope with 300-330rwkW worth of fuel delivery.
FYI, Eltham United is listed as having E85 on the United website, but they do not and will not. They dug up the forecourt to install the pumps and line then figured out they have fibreglass tanks. So no E85, ever, at Eltham :( that's dinted my E85 ambitions and made a setup which can handle both 98 and 85 a must.
Whats wring with fibreglass tanks? All new caltex sites are getting fibreglass tanks to replace the old steelies
Not every one is sensible like Roy the old lady. Kids these days
yes the simple things in life are often the best..but that said somebody has to pioneer the new ideas..
Any dope can build a 300kw skyline these days its a no brainer cause its all been done before..
Trying and testing new things is what sets you apart from the rest and in a few years everybody will be running E-sensors and flex fuel and wondering why we ever did it any different..What is needed now is an ecu smart enough to know how much to adjust the tune without the need for the tuner to make multiple maps..My setup shows it needn't be overly expensive. I have spent barely 2 grand all up, thats as much as a new PFC was back in the day and as today's ecus get cheaper 2nd hand more and more people will adapt to the new tech..I believe atm the only thing really holding alot of people back is the need for so much dyno time to set the multiple tunes up..but most of us end up back at the tuner every 6 months anyway cause we change something or other so why not setup for it now and it won't be too long before you have enough tunes in your log to make a decent enough coverage for flex fuel..There will always be dinosaurs like Roy showing us how it used be done and that's good..Cause dinosaurs are cool. :D
Yes sets us apart cause we are broke ass mutha's for being the pioneers :)
AFR can vary between two engines. I am not a tuner - Sean at EFI Performance (07 3801 8075) does all our tuning and we always use a combination of AFR and EGT sensors. One engine can be 750-800 degrees at 0.95 lambda whereas another can be 750-800 degrees at 0.8 lambda. It all depends on engine efficiency etc.
The rule we use for E85 injector sizing is 1200cc of fuel for every 100hp at the wheels
The thing you are missing with Methanol is the rate of evaporation and even considering its calorific content per unit of mass, methanol has a higher content of oxygen so when it burns you get a leaner mixture
Now before anyone jumps on me about injector sizing and 'oh but I made xyz hp on abc injector' etc....it is designed to be a safe level for injector sizing. With those calculations, you will NEVER have an injector size problem unless you increase the hp.
Most of these engines need 10.5:1 AFR as they come up to peak torque but seldom do we ever see that when cars come from other tuners......and that's why the engines that Sean tunes for us live a very long and healthy life.
A man's worth should be judged by his achievements not the money in his pocket. ;)
besdies Im a broke ass mutha regardless...
And by his skidz! I'll be broke for the next 2 years due to the mods i just went through...... Worth it you ask?.........................................................Fark yes!! :woot:
I think most cars from other turners don't have AFR's that rich because they don't believe it's needed. I know we sure don't have a need to tune that rich and don't have issues (very long and healthy life motors), but if it works for you then all power to you.
Fugged if I know.
I dropped in there yesterday and asked what's going on as they are listed as having E85 on the website. There were two guys behind the counter, one stared blankly at me, the other clearly knew what I was talking about. The knowing one said they dug up the forecourt (which you could see) to install the required lines but then figured out that the tanks were fibreglass and therefore unsuitable for E85.
Would be interesting to hear from someone in the know. I assume the alcohol and fibreglass resin probably do not get along too well? Anyone know the chemical reason (assuming that is the reason) why there is a problem with putting ethanol into FG tanks?
In your case, with a single 044 running the show, your tuner probably has no choice.
I'm also referring to cars that actually do fast 1/4 mile times. They are the ones that matter
What are your EGT's?
    • it was good to see our presence at GTR festival..hope to see more SAU at these events
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
    • What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup. If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily. The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.      It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good. Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past. What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
