I did a bit of a search and it didn't come up with anything meaningful.
I wanted to know at what approximate mileage people are replacing their;
A) engine mounts and
B) gearbox/transmission mounts
Apart from slight vibration at idle and clunk of engine when shifting from drive to reverse, what are other symptoms?
Also I understand that the C34 Stagea 4WD uses the same as the R32/R33 GTR engine mounts.
Do most just replace with aftermarket Nismo ones ( a bit stiffer I think) or other aftermarket ones? Anyone priced genuine ones lately?
Edited by RS4StagMan
I changed my rear transmission mount a few weeks ago (1999 S2 Automatic RS4)... I posted it in the "what have you done to your stagea lately"
There was a slight vibration under load which got louder in the cold and wet weather. It has made SO much difference, I had been troubleshooting the vibration for ages!! My car only had 140,000 on the clock. Part number: 1132001U01 and was about $200 with the replacement rubber bushes for the bottom transmission brace. From my research I couldn’t find a Nismo equivalent.
Supposedly its a bitch to do the engine mounts, but as I haven’t done it (only heard from my mechanic) I could be wrong.
Just ordered the Nismo set from Nengun: 2x eng mount, 1x gbox mount: cost $268.88. It was the cheapest I could find from a trusted supplier...
For the record, I think my shell has around 160000km on it, but the engine and gearbox were swapped in about 20000km ago: not sure how old the shagged mounts are...
Do you have any pics or description of the suspect trans mount, any DIY instructions/tips that you would like to share? How did you diagnose it in the end? Any pics of the one you took out?
How hard would it be to replace without a hoist?
Was yours also idling roughly as well as getting the vibration under acceleration? Assume there was no vibration when just cruising. Was it rev specific?
Looks like Kudos Motorsport has them in Genuine Nissan, under $100 + delivery, gearbox mount.
http://www.kudosmotorsports.com/catalog/nissan-mount-gearbox-genuine-nissan-r33-gts4-071997-p-498.html
Mount, Gearbox, Genuine Nissan R33 GTS-4 (07/1997 - On)
Product Details
Manufacture: Nissan
Manufacture Part No: 11320-01U01
Availability: In Stock
Your Price: AU$94.60
Shipping Cost: Starting From AU$13.20
*Payments made using PayPal will encure a 3% surcharge.
Product Description/Information
Genuine Nissan gearbox mount to suit the following applications:
Nissan Skyline, R33 GTS-4 (RB25DE, 07/1997 - On, A/T & M/T)
Nissan Skyline, R34 25GT-4 (RB25DE, All)
Nissan Stagea, WC34 (RB25DE, 06/1997 - On, A/T & M/T)
Nissan Stagea, WC34 (RB25DET, 06/1997 - On, A/T & M/T)
This product was last updated on Wednesday 11 July, 2012
Sorry mate don't have any pics of the old mount, basically the "insulator" (as nissan calls it) part of the mount was not as thick as the new one. This caused the transmission to droop and as it was on an angle would vibrate under load. In the later stages the vibration was really loud (especially when wet) as the "insulator" part had worn away and it was just metal on metal. Wasn't rev specific but i noticed it would be louder stationary.
I only found out it was worn from the muffler shop (hats off to HiTech Mufflers) as i was thinking it was my exhaust vibrating!
I wouldn't want to try changing it without a hoist, keep in mind you will need to support the transmission (jack or what ever) while you remove the transmission cross brace.
The mount is only $100 but the other 4 rubber pads (11248) should be replaced too (mine were totally gone and added to the transmission drooping further). These are $25 each (rip off i know).
Hope that helps buddy.
Adrian.
Adrian.
Thanks Adrian, I will be sure to check mine when I'm next under the car.
Was the car also idling slightly roughly (side mirrors slightly moving) as well as the metal on metal vibration when stationary?
    • Post it up on YouTube and a non public video and dump the link back here, it embeds it. Imagine you have a Borg Warner turbo, you'll probably end up driving home without boost 😆       I kid I kid....
    • Chrome surrounds back on and polished up, no idea why some knob would prime a single piece 🙄
    • Well, in the same way that you can't tell any SUV from any manufacturer in any size category from any other one, "sports" coupes now all look identical. Stand back and squint your eyes and the Supra and the 400Z and the GR/BRZ things all look the same. I was just thinking last night, when sitting behind a Subaru CrossTrek, that I have no idea what it is, how it differs from an XV, or a Forester, or an Outback, or anything else Subaru offer, and I couldn't tell if it was supposed to be small, medium or large. I contrasted that to the good old days, where a HQ Kingswood had familial similarities to an LJ Torana, but there is no way that you could confuse them, and how a bit later, the HX Kinger and the concurrent Torana and the Gemini all had familial similarities, but you still could not confuse them. Ditto the ugly Fords and Chryslers of the era. But now, a RAV4 looks like a Kluger, looks like a Yaris/Cross/whatever they're calling those stupid f**king things, looks like every other Toyota that's not a Camry/Corolla sedan.
    • The Prelude doesn't look that bad without all that lens distortion in those pics. Makes it look disproportionate when it isn't. Actually I kind of liked it at the Osaka Auto Messe earlier this year.
