SUMMONER!!!!
Cam here how ya doin man.
i got my RSM from Car Quest, $400 for RSM plus $80 for G-Sensor, i put it in myself, pretty easy, except the manual was in japanese, so had to go online and get english version, i didnt see any commodore wiring diagrams in there though??
anyway come and have a look and see what it does next time ya see me if ya want, i rekon the RSM beats the hell out of G-Tech anyday, looks heaps better and does more and only a little more expensive.
Cya round.:)
https://www.sau.com.au/forums/topic/4045-apexi-rsm/page/2/#findComment-65555
yeah there pretty good, dunno how accurate they are but they are supposed to be accurate to within 0.01 of a second but ive never been down the quarter so i dont know, the h/p reading was pretty accurate though, that was spot on to what the dyno read on my last car.
https://www.sau.com.au/forums/topic/4045-apexi-rsm/page/2/#findComment-65564
i have the older style RSM, the one before the blue screen but its basically the same.
I set it down on the quarter and on a few runs it was spot on, and the rest were only 0.1-0.2 seconds off the mark. It all depends on wheels spin as it reads it from the distance travelled.
So in theory you could do a 400m quarter on the spot :)
Shaun
https://www.sau.com.au/forums/topic/4045-apexi-rsm/page/2/#findComment-65604
Originally posted by HJB
RadiuM,
I have the older style RSM in my R32 as well (When its arrives, should be a week or two). Once it arrives do you think we can catch up at one of the events and you could run me through the RSM functions?
yep, no problem.
its quite simple, i just played around with it a bit until i figured it out.
R33_cam, nope.. don't think the older one came with a G sensor (checks manual) but the new one might compensate for this.
We installed a new one in a mates car, I love the G sensor graphs, just like the R34 GTR. hehe :)
Shaun
https://www.sau.com.au/forums/topic/4045-apexi-rsm/page/2/#findComment-65838
:lol: yeah i think alot of the features are there to just look good :lol:
hks-s14::
they are pretty accurate with distances i rekon, measures to 0.01km (i think, don't quote me on that), its all resetable whenever you want, and can record your best times etc etc
now all i need is the SAFC sitting next to it, that would look sweet and mite actually make it go a bit better too....:)
https://www.sau.com.au/forums/topic/4045-apexi-rsm/page/2/#findComment-65874
  • 8 months later...
Just thought id let u guys know that Skylines Australia does not condone any of the silly behaviour as described in this thread. If you break the posted speed limit you run the risk of killing yourself and others and we all know nobody wants that. We have already had a couple of incidents in the fold over the last week or 2 so lets not go testing our RSM's to see if we can beat the land speed record eh?
If you really feel complled to give it a good test, Moroplex is open most weeknights for a small fee and its alot safer and legal there than it is on public roads. :D
Oh, no more references to illegal activites please. Any more and the thread will have to closed.:uh-huh:
https://www.sau.com.au/forums/topic/4045-apexi-rsm/page/2/#findComment-353325
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
