Hi there. My r33 jerks when its in low gear and applying light throttle (around carparks and such) its not an engine problem Its more of a delay when I put my foot on the accelerator and let off and then jerks back and forth a bit if im not super smooth when pressing my foot down. I'm quite sure it's mounts however they all look fine and I was wondering if someone knew which mounts it might be? Engine, transmission or diff? It is a manual by the way, and no matter how smoothly you change gears, when you release the clutch it often clunks a bit, just feels very sloppy so im quite sure its a mounting bush that's stuffed somewhere. Have no Idea which one though. If anyone else has any info that would be great!
I'm very used to clutch and its in good condition as far as I know. Not sure what diff backlash is but it's not a metallic sound, more of a thump or thud if that makes sense, when reversing out of the driveway slowly as I push the clutch in to disengage I can feel movement in the gear stick and there is a slight thud. Like I said I don't think it's an engine problem because revs don't change its just the feeling of the car. You know when you first learn manual and do a few kangaroo jumps? It's a similar feeling to that although it does it when it shouldnt. And under reasonably hard acceleration if I go over a little rut in the road the car jerks quite a bit and feels terrible when the rear wheels go over it.
Try to visually inspect engine and gearbox mounts.
Diff backlash is the freeplay between the gears in the diff. If there is too much freeplay (backlash) there will be clunking etc
what about a vacumn leak?
mines had a leak and i think thats what caused it to be jerky on low revs, when your driving and put the clutch in to change gear the revs will fall fast instead of steadily and that contributes to the next gear going in with a clunk
also a bit of clutch shudder can cause some symptoms when reversing slowing.
I'll have a closer look at the mounts tonight, was just wondering if anyone else was experiencing the same problems who has fixed it before. I don't think it is backlash as like I said its not a harsh metal clunk. The jerking happens when in gear, clutch pedal fully released so it's not to do with the revs dropping but good idea anyway.
Ok i have had a closer look and Im pretty sure you are right about backlash. All the bushes look mint, nothing wrong with them, but with the car jacked up and in nuetral there is a fair bit of play when i turn the driveshaft before the wheels engage. Does anyone know how to fix this? Will shimming the diff solve the problem or am I up for a new diff? Thanks guys
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
