hey does anybody know where i can get one of these bad boys from in tasmania...? ive had 0 luck, even tried going to the local mechanic and ask if i could pay to use his but they didnt even have one.....
or if anyone is willing could they help me out using there socket or something?? willing to pay......
https://www.sau.com.au/forums/topic/404563-oxygen-sensor-sockethelp/
mate i used a ring spanner. note mm but the other one. (im crap with metric and imperial) it was the equivalent to a 22mm well bit bigger because 22mm wouldnt fit. tiny bit of pressure and it popped undone! hope all that makes some kind of sense to ya chap!
Because like everyone else they use a shifter.
There are heaps on Fleabay...
dodgy ass shifters and crap...gah
yeah use a spanner. i cut the wire off my old one so you don't have to worry about it, then use the right size spanner. the angled head on the spanner is about the same curve as a standard dump pipe. and is easiest to get to from under the car (believe it or not). i couldn't get to it at any angle from in the engine bay, even with the heat shield removed off the turbo.
Your local snapon dealer can get you one.... they're not really that expensive.
Or get the right size 'crows foot' spanner attachment for you socket set ratchet and extension.
Or heat it up and give it a little tap, then undo it with your fingers.
Or buy a cheap ass tube socket of the right size, then chop a 1/3 off one side.
Or buy two cheap ass sockets, cut the back off one and weld it to the front of the the whole one.
Or ....
im over it
Justin.
thanks guys yeah ive got a spanner and that to remove it but i had the problem as above, couldnt get to it from the engine bay....ill try and get to it from underneath...?
its not that its hard to remove its just that the spanners i have are too large for the engine bay =/
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
