  • Replies 48
you guys are f**king arseholes, kid just wants some advice and you guys just give him smart arse reply's.
what you need to do mate, is angle grind off one of the runners (ideally #6), only one otherwise it will sound like shit, then chuck some exhaust putty up the remainder of the runner on the side that goes to the turbo, the more the better, you don't want it to leak. then say hello to your new screamer, straight out the engine, doesn't even get muffled by pesky piping or the wastegate itself, so sounds even better than external gate, will be killa.
https://www.sau.com.au/forums/topic/404591-ex-gate/page/3/#findComment-6445754
ok seriouse what you need to do is remove the gasket between the plenum and motor bolt it all back up then listen to awesomeness
I had the wrong gasket and it sounded like the worlds loudest fart, it was like a trumpet that made you go deaf on boost. Everyone would look around to see where the gigantic ass was.
https://www.sau.com.au/forums/topic/404591-ex-gate/page/3/#findComment-6448067
