Hey guys I am new here and fairly new with turbo modifications, blow off valves .
I Have a Nissan Skyline r33 25GTS-T 1995 completely stock besides a pod filter and cosmetic upgrades.
When changing gears it goes Vvruum tushh , but I want it to do the classic awesome sound Vrumm tush tush tush ...
Sorry if I sound silly hard to explain , how can I get this ? Do I need to boost my car ? Upgrade blow off valve ?
Also my blow off valve is plumb back
Don't want any silly comments please just after some help heard you guys are good..
I'm after that like flutter or "dosing " sound ... Currently it just makes a one release of air pressure type sound ..
As I said I am new to turbo charged upgrades
Thanks in advance I will have a look on YouTube if that helps ...
yeah you want a really good BOV...make sure you spend alot of money on it cause the girls wont show you their boobs if you got a cheap one
this ones dope
http://www.ebay.com....=item2ec00ed88a
Didn't realize blow of valves are that dear ... Do you need something this expensive ? I'm not looking at making it like race ..
Upgrades I was looking at was a HDI intercooler and a 3 " catback hi flow exhaust with a canon and possibly a boost controller
I was being VERY simple with my instructions.
Someone knowledgeable explain it.
Without starting a BOV vs. No BOV debate.
Was not trying to like insult you just from what I have heard that you need it and it's there for a reason , without it the pressure builds up wears out the turbo faster and puts more pressure on intercooler ect ect
I.
Fucking.
Dislike.
School.
Holidays.
Mate I don't go to school I am 22 and work at the mines , like I said before I am new to turbo charged modifications and was told this site the guys here are helpful . And I hate school holidays to , far to busy for when I am off work, everyone drives like 10 under the limit wtf must be the teachers
People here are EXTREMELY helpful. They just get over the same threads being started countless times, asking the same questions over and over again, when this thread has been covered 2000 times since the site started..
To answer you, cheapest way, block the BOV off. Expensive way, buy a new BOV and tighten it up so it doesnt open under lower boost shifts.
Turbo damage debatable. With the stock, ECU, the drive ability will suffer.
Cue R31Nismoid's pre written Thread lock post soon?
Yeah I understand that would happen ..
Thanks for that
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
