Hay Kate!
Welcome, hope you enjoy your stay. Lots and lots of info in here. If in doubt use the search function and you should find some info. Can recommend people to work on your car too should something need attention.
Dont worry about the trolls. Plenty here. Provide the Lolz mostly.
https://www.sau.com.au/forums/topic/404603-newbie~~~/#findComment-6446185
Haha no problem, thanks! Yes that would have been I remember I saw your post in spot the stagea.. :) looking at going to the cruise on 22nd, should be good.
You will find a lot of usefull threads on here and the meets are great too....
https://www.sau.com.au/forums/topic/404603-newbie~~~/#findComment-6446721
had a quick look at your profile, definately need to put some pics up (of your car please) and also yes i'm still i believe the youngest active member on here at 22 yay!! glad to see i'm not the only young person who likes these cars, my mates all give me so much s*** for driving a wagon, even though i need the space for work, and for my son.
https://www.sau.com.au/forums/topic/404603-newbie~~~/#findComment-6447212
Oooh, I could be younger :-)
I'm 23 in November
Also, welcome to the stagea girl
https://www.sau.com.au/forums/topic/404603-newbie~~~/#findComment-6447524
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
