Hey guys
Dont know how many of you saw my video getting played at Autosalon at the Ovaboost display but the video called Boosted is nearly ready for sale.
The final product will have an extra half an hour to what was being showed brining it to 90min total. For those of you who havent seen it the video is an underground style of video showing the WA car scens on and off the street. Footage inlcudes project cars ( one of which is GT51R ) Kwinnana drags, motorvation, autoslaon, cruises, night cruises, street drifting, street drags
It should be ready mid June and cost $25 . If you are interested let me know by replying to this post
https://www.sau.com.au/forums/topic/40464-boosted-video/
glad you guys are interested.....few of you might see yourselves on there....if not theres still plenty of skyline footage to watch....
yeah its a dvd
its getting its leagl classification and all the professional artwork done and alll that stuff at the moment.....basically selling price to cover production costs.
All facets of WA modified car scene is on there.....700hp GTR's racing each other
cruises, night drags, project cars, street drift, kwinnana drags, motorvation, autosalon, MC motorsport aand general look at car nuts being nuts
if youve seen mischief 1 that will give you a dort of feel of the type of DVD it is.....we didnt want $100,000 production cost with some dumb shit presenter at a racetrack or a car show......wanted am inside ( or underground if you wish ) perspective o the car scene
https://www.sau.com.au/forums/topic/40464-boosted-video/#findComment-832155
yeah im interested to see this
p.s. hope its all your own footage, if it is, all the best with the dvd.
isn't it funny how everyone is interested in seeing illegal street drags and illegal street drifting in perth, and supporting it by purchasing a dvd, yet if you talk about it everyone is like
'no we dont get involved in anything illegal like that'
'we always stick to the speed limit on our cruises'
'drifting and dragging on the street is stupid, keep it on the track'
its pure gold!
anyway i love seeing street action so keep us updated
https://www.sau.com.au/forums/topic/40464-boosted-video/#findComment-836767
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
