Hi guys ok. my r33 gtst s1 is feeling rattley and verry uneasy to drive i think the bushes are showing there age so i think its time to start replacing.
What i would like to know. Is which bushe/bushes are the most common to go that way ill get them first. the biggest uneasy thing ive noticed is i can feeleverypothole through the stearing wheel and i can feel little jerks as im driving and its getting anoying i have about 1 week till i take holidays through work so id like a list of all the bushes i would need so i can grab the parts through the week and work on the car on my time off.. Thanks
https://www.sau.com.au/forums/topic/404676-bushes-what-needs-replaceing/
Best thing to do is just jump under your car and look at what looks a bit suspect
hard to say what you should replace without knowing what is actually worn. Other then saying replace them all.
I've only had to change my front sway bar D-bushes in the front end of my 33. Have you still got standard suspension? Might have something to do with it also
Jump under and see what bushes look worn
hey mate, i've replaced pretty much every bush in the front end as I was getting knocking noises and I wanted to freshen up the steering since the 33's are getting on a bit. Here's a list of what i replaced: lower control arm ball joints, lower control arm bushes, tie rod ends, upper inner and outer control arm bushes (camber adjustable), swaybar endlinks, swaybar d link bushes, bc-br coilovers and hardrace castor/tension rods or you can just replace the castor rod bush if you don't want to replace the whole arm. I ended up replacing all bushes with superpro and cost roughly $350 from memory and about $100 for tie rod ends and ball joints. To get the old bushes out I recommend taking it to a mechanic to get the old bushes pressed out and the new ones pressed in. I took the control arms off myself to save some money. F*ck me was it worth it though lol. now on to the rear end bushes
Assuming you did the inner rack ends as well?
I have those solid caster arms on at the moment but haven't adjusted them properly, they are at Mac caster and it follows every groove in the road, it's not overly nice....
Thanks guys for the input i appreciate it all ive had a gander at some of the bushes and they look really weathered cracked and looking really dry so id say the lot needs doing the only suspension work done to the car is a set of extremly stiff tien d10s the car bounces a hell of alot im not worried about it bouncing im more worried about the knocking the car doesnt feel sexy to drive anymore.. I just wanted a run through of the suspension because im currently doing an engine swap for another rb25det from a wreckers as the cureent one fitted seems to have a worn out big end bearing causing knocking on start up so to keep my mind at ease ill be putting another second hand unit in it whilst i rebuild the other one.. the car is my daily driver yeah its not the best looking 33 it doesnt have the best paint job and everyone tells me to sell it but i just can not spend a day with out driving her so yep engine swap in 2 weeks then focusing on suspension.. once again guys thanks =D
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
