Ok guys I need help. I've got a r32 gts t making some serious hp. Nothing has broken so far touch wood in the are end department (wheel spin is my friend) but I want toupgrade and fix the problem before something does break, ie at power cruise. I have a crashed r33 I was wondering will that whole rear cradle bolt into the back of a 32 or wat can I change to upgrade this using both cradles. I doubt want suggestions of going to a full 9" conversion I want to utilize the materials I have available to me . Any feedback would be appreciated
Cheers
https://www.sau.com.au/forums/topic/404718-arse-end-conversion/
I'm not sure if I understand what you want to achieve. The R33 rear cradle is only slightly better than the R32 one. It's not the cradle so much that is better, it is the suspension arms that are slightly better. But many many R33 cradles sit off to one side of the centreline of the car. I'd want to know that any R33 cradle I was aiming to retro into an R32 was not going to bring that problem with it.
I tore out the HICAS cradle in my R32 and replaced it with a non-HICAS one from a Cefiro. That fixes one big problem with Skyline rear ends. I replaced the VLSD with a helical centre. That fixed another. The R200 diffs are pretty strong. You have to be making massive power to do too much damage to them, and there are plenty of aftermarket centres avaialble with any amount of lockedness anyway.
Ok I prob didn't explain it real well my bad.
Instead of pulling my actual cradle out all together is there anything from the 33 rear end which I can put across into the 32 to toughen it up
I've thought of going the gtr option as I know they ar a lot stronger but was trying to use wat I had available first
Im pushing 800 at the rears so power isn't a problem. My mate said he has only had dramas with the half shafts not being up to the task in his 32
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
