  • Replies 202
Posted Images
Heya all :)
Any vids/pics of GOD12A (charcoal 32GTR on black CR Kais) ripping skids?
My mates expected everyone else to bring their camera/video gear. Kids these days...
Any media of those tyres going to heaven would be appreciated!
Mark :)
You fellas that want video need to help out with the timing & BBQ so I can break out my gear. Brought it on the day but it never saw the light of day cause I was too busy running around behind the scenes.
(See you do miss my videos - you know it!)
This man, he shares wise words!
I actually commented to Anna I thinknit was on the day that it's a shame people wouldn't pay matt and/or kory for their services as they take marvelous photos. And here we are with a distinct lack. Unfortunately after they come out for te first one, everyone will cheap skate it and bring their own cameras.
Unfortunately Ian, I can vouch for this first hand.
Hey next time come up and see one of the officials and we'll throw you a hi-vis vest so that you look all official like. Thanks for the pics.
I keep seeing you around, but every time I see you I stand there going "whats his name, whats his name, whats his name, whats his name, whats his name, whats his name, whats his name, whats his name, whats his name".
I've seen you at a few Texi's & filming cars at the lowdown the other week i think i even saw you randomly in public aswell.. I'm normally good with names.....
find the sexiest person on the day
and say "hi andy, i'm looking for execs"
Oh Owen you big smoothie, you say all the right things. Just remember flattery will get you everywhere hahahahahah
I must say you can never have enough pics of your own car with smoke pumping off the tyres bro. Plus we all know how much chicks love burnouts! Drives them wild. ?
Hahaha classic
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
