Hey everyone.
well ill got a letter from our favorite people the EPA.
I need to send my car in for a noise test. So I'm looking for someone in Melbourne that has a R33 gtst stock cat back exhaust. I will only need it for the weekend and happy to pick it up and drop it off and also supply you with some funds for your time if you like.
You can text me your number and i can call you or you can call me on 0437199496.
I have till the 24th of July to do the test.
thanks for reading!
Edited by greddy_skyline
https://www.sau.com.au/forums/topic/404755-epa-epa/
Hey everyone.
thanks for reading!
Send me a pm
https://www.sau.com.au/forums/topic/404755-epa-epa/#findComment-6444462
  • 3 weeks later...
    • Honda's hybrid system can be easily scaled up to PHEVs. Series hybrid at low speeds, at higher speeds the engine directly drives the wheels but there can still be some power bled off to charge the battery + the electric motor can still provide parallel assistance too. It's really only a question of will at that point. Toyota's PHEVs are selling incredibly well at the moment because of the flexibility. You can run on EV mode when it makes sense, but if you're planning on doing a long highway drive you can still fire up the gas engine and not have to worry about dealing with the rather miserable state of public charging infrastructure.
    • Only reason to keep a MAF on your RB25 is to be able to easily calculate true VE if you know what the factory voltage curve represents in grams per second of flow. Also allows you to do things like pull the original OEM ignition + AFR target tables and use those as a starting point for your base map. Once you're well and truly done tuning though there's no need to retain the MAF.
    • Do you think they'll merge there performance divisions and we'll end up HoMo?
    • Very true, if buying new, I would not get an PP either. Minimum is an Elite 2500, which is also considered outdated. Get something that supports DBW, delete that cable throttle. Best thing I've ever done to the Skyline, next best is refreshing the A/C with a new condenser. It's cold, but not as cold as modern car, but colder than most 90s JDM shit boxes imported into Australia.
    • Haltech have a nice comparison table between the Elite and Nexus models -  https://www.haltech.com/ecu-buyers-guide/ In general, the Nexus is better. Haltech have some nice product videos on their YouTube page, I'd have a look at those and if you're still not confident what way to go, I'd give them a call. They have the best customer support of any company I've dealt with, I'm sure they'll be able to help you out.
