Hey guys,
Can anyone recommend a good cheap lowering option for my R33 GTS-T (1994).
It has been suggested to me to get a set of King Springs and lower it with them.
Not the Super lows' , but just enough to make it look a bit slicker! About 30mm.
I do intend in the future (12 months or so) to get some Tein adjustable suspension, but until the pesos materialises I would like a cheap alternative that won't make the ride to stiff as I drive it 500k's per week!!
Look forward to your responses.
Cheers,
J-Flash.
https://www.sau.com.au/forums/topic/40477-good-cheap-lowering-options/
thats as cheap as it gets mate.....other than choppin ur springs which i hope nobody does anymore:D:D good advice is to shop around for prices and ask if peeps know anyone if u know what i mean. my mate scored a set of brand new kings for $150 on all corners of a mates mate.....and we spent a good couple hrs puttin it in....BARGAIN!!
MR_Fanny,
Did ya lose any smoothness in your ride. Does it hit the bumps any harsher!
I'd rather do nothin' if the difference is significant.
Thanks for ya comments. Ya couldn't get me a set at thta price could ya! wink wink nudge nudge.LOL
Cheers,
J-Flash
At all cost do not chop your springs.... Get a proper lowered springs like King Springs you won't regret it.
Get a progressive rate spring, it will stiffen up under heavy load/cornering but is comfy for cruising.
i lowered mine with r33gtr front shocks and springs(bolt straight in)
back shocks were fitted with gtr springs
front is 50mm lower than standard
rear is about 30mm lower than standard
lots of gtr shocks floating around cheap coss everyone fits flashy shocks to them!!!
ride is actually better with these fitted than standard
cheers
I can go one better...
Meet HOTLNE... a perfect example of what not to do to your car... this mucus coloured R33 sporting vinyls that were bubbled, wrinkled and peeling off, also had a unique modification of NO SPRINGS.
yes the driver had the car sitting on its tyres, and drove around with no springs from the 2003 VIC Glo Show back to whichever rock it crawled out from under.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
