Yes it would work, GT non turbo r34 dont have the cutout on the dash from what I recall
Its not a big deal since the triple cluster shape is already there embossed in the dash, most gauges would hook up with a bit of fiddling or come with senders
So drill a small hole and cut the dash center out , its marked off for you or buy a Gtt dash , plenty around cheap just a bit of labour to get it out
I'm making a mold for carbon clusters ( most of the plastics in the car !! ) in a few weeks and can leave the holes uncut for any standard size to fit , pure carbon not covered plastic
Are you planning on making these to sell, or for your own car? I've been looking for some high quality carbon dash parts without having to get them custom made for quite awhile now, so I'd be interested if you're planning on selling them?
OP, the standard GTT triple gauge holder fits straight into the GT, I've done it in my car.
I know of someone who had a GT and the dash wasnt cut out ? But converted to gauges easy
I'm making them as a Small hobby And since nobody else did any lol? , mine is widescreen tv and gauges where ashtray and cig lighter was and in roof where sunroof /dome light was So not for my car
Doing just about every plastic part off Gtt engine , outside . Inside
How do you mean it wasn't cut out?? This is how my dash looked previously (ignore the somewhat ricer interior, I was young and stoopid) and all other GT's I have seen:
Underneath that section where I have those gauges mounted is exactly the same as the GTT. My interior now looks exactly like a GTT's, one couldn't tell the difference.
The actual dashpad was 1 part the insert was embossed into it not a seperate part ? I have a brochure from japan and from the looks of it they came both ways ? the brochure has 7 different 4 dr models and 5 coupe models not including GTR !!! and shows all the options you could get ? Lots people dont even know existed i think
The carbon and kevlar i have is in various colours and weaves ( not colour fiberglass but real kevlar ! ) also making pure carbon strut bars no metal
And intercooler pipes in carbon factory first to replace the metal ones in front engine bay area , can be made any size from 2"-6" diameter one piece not wound or pieced together
Dry carbon, satin, normal or super wet look UV stable
Edited by Carbon 34
Yes it is one piece, you have to cut the section out in the GT to fit the GTT gauge holder. But underneath the padding, it's all exactly the same, so the bolt holes etc. are all there. Very easy to do if you've got a steady hand and a scalpel.
Your carbon/kevlar parts sound the goods, have you got a website or is it just something you do as a hobby? I tried working with carbon fibre once, ended up ruining my gauge holder :( lol. On the look out for a 100% carbon replacement for it, so if you are successful and plan on selling them, let me know!
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
    • I don't believe I posted pictures of the second oil pump pickup I added so here they are. Data shows it gets oil pressure up to the relief pressure much earlier in the RPM. Is that important? Not likely... This was just another attempt to fix the bearing issues.   I also heavily opened up the inlet to the pump since it now had to flow oil from two pickups. I believe the diameter increased about 1/8".
