Magick's N/a R34
Hey everyone,
Im brand new to the skyline scene, its my second car after i moved on from my minitruck project that I completed while I was ill.
I thought id start a thread on my n/a 34 that i picked up on Friday, I opted for the n/a as Im currently on my green P's. Im a first year apprentice so as you can imagine money is tight, especially after forking out my savings on the new car. I love the thing, rides great, sticks to corners and is a nice looking car! Its a completely stock 98 model apart from a polk audio system, and has 90k on the clock.
My plans for the car are to first install a set of coilovers, set of nice white wheels and just tidy up a few little things on it. Not too fussed about trying to gain power out of it, that time will come when i sell it for a gtt down the track.
Anyway here are some photos of the 34.
my old ute I sold for the skyline!
The new girl
As i dont have much funds for the major mods, i thought I would give the interior a touch up. I scrubbed up the old dash surrounds and resprayed them in silver. Came out quite good i think!
Next I just gave her an oil and filter change and checked over the engine to make sure everything was in good order
Bit unlucky with the plates.. haha
Feel free to give me advice and point out things Im doing wrong, as I said, im very new to the skyline scene!
Thanks, Luke
  • 1 month later...
A few weeks ago i ordered a set of BC, BR coilovers from JustJap. They turned up last week and as soon as I knocked off work they went in!
Very simple to install, just 3 bolts and its all good to go. I was happy with the height they were set up at, so I just made sure they were all the same and tightened them up. End result dropped the car by roughly 2 inches, and improved the handling noticeably around the local range!
Before coilovers..
After..
Saving for wheels next, thinking white 18x9.5 +35 rear, 18x8.5 +30 front.. would love work XD9's, but will probably end up going with rota grids.
P.S, anyone want to clean swap a silver or blue 34 hahah, black cars and long dirt driveways are so painful!
Black cars full stop are painfull! My 4wd is black aswel, worst idea ever.
I have gun metal grey Rota Grids on my 34, suits them well i reckon. Ive gone for 18x9.5+20 with 235/40's and its a real agressive fitment, required a lot of work but looks mint. 18x9.5 +35 will fit nice and flush on the rear, and in the front id go for 9 +30.
And good work saving and working hard for such a nice car.
  • 4 weeks later...
Thanks mate!
yeah was going to go with what you stated.. although I popped into Option 1 Garage today and test fitted some wheels and tires and completely changed my mind haha
They threw on a couple of sets of rotas, both 9.5+20 all round. Fit perfect on the rear and pokes a little on the front. Will be getting it rolled and the fronts pulled by a mate who is a panel beater/spray painter.
If they still stick out much I will invest in some hardrace camber arms that they had in stock.. Can not rate Option 1's customer service high enough, offered to test fit straight up and offered whatever i wanted.
Been trying to decide on style and colour all day, I'm tossing up between white or black grids. Although I did like the gold meshies for something different.
Edited by MAG1CK
Not much of an update,
Got my guards rolled by a mate, did a good job, also managed to slightly pump the front guards out a bit, didn't crack the paint either!
Looking to get a professional "cut and polish", few small scuffs and swirls over the whole car from previous owner :(
If anyone can recommend someone around Toowoomba/ Brissy/ coast, that would be great!
Does anyone know much about this front bar?? stumbled across it the other night while looking for gtr replica bumpers.
http://www.ebay.com....=item3f1a288295
Finally a pic, trying out the in build HDR in my Camera for the first time.
Cheers, Luke
Edited by MAG1CK
  • 1 month later...
Nice work on the 34 mate. Love your choice of wheel colour! I know what you mean about black cars, but hey nothing meaner than a black 34!
Thanks mate, exactly right haha
Unfortunately this is now for sale, read more in the for sale section!
  • 2 months later...
  • 1 year later...
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
