Prob going to sell this rather then use it. Neo bottom end with the following mods
- crank grub screwed and crank collar fitted.
- new acl race bearings
- Hastings rings fitted
- arp rod bolts with rb26 prepped rods
- oil restricters and block of fitted
- mls head gasket
- block has been washed, cleaned, honed and decked.
-brand new nitto oil pump.
Motor has perfect compression, works well. decided to go down a different path.
$1700 as is or $700 with no oil pump.
located Para Hills SA
Contact me via PM
interested! when I get my head off in the next few days and inspect the bottom end ill know if I need this.
Would shipping be an issue to NSW?
i thought the neo pistons were diff and you could only use the neo head?
im keen on the block with pump, if a 33 head can def be used here :yes:
from wat im aware u can fit any head on a neo bottom end but not a neo head with any pistons.. they need to be domed for clearance
hope this helps
Cheers
I had a 26 head on this with no problems.
The Neo and non Neo pistons are same deck height and pin height but Neo piston is stronger. The difference is in the Neo head.
so all in all. Any 25 or 26 head will work
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
