Hey
Summer is coming up and I'm thinking I will paint my car for some cruising around.
I've chosen the paint, but my mate said to me why don't I think about getting some wide
fenders for my car. My car just looks standard at the moment with drift teks. I've seen tones with
wide front fenders but not rear. Just wondering if any1 has done this or seen it
If any1 has pics it be a great help
https://www.sau.com.au/forums/topic/404845-r32-4-four-door-wide-rear-fenders/
  On 16/07/2012 at 7:00 AM, CavemanNZ said:
omg your car looks so mean. I hope my car look even half as good. love your colour too. how did u fit ?
haha thanks.
we glued them on, then shaved and glassed them onto the body, then bog. lots and lots of bog. took us about a month and a half to complete.
  On 16/07/2012 at 12:12 PM, luke GTR said:
pay someone else to fit them....
easiest way :thumbsup:
but theres no fun in that :P
Oh real sounds like its going to be intresting but ill have fun did u have to cut the original guard at all ? and yeah ill keep my eye out if i go
to one.
have you heard of trademe.co.nz its like ebay but 4 NZ there tones of random skyline stuff on it and they sometime send stuff overseas
all ill say is, if you have the means for metal guards, do that. because with glass youre going to get ripples and you can bog them till you think its straight but youll still have some ripples here and there
  • 2 months later...
  • 1 year later...
    • You would need to paint your hardtop again though
    • I have an old R32 in the shed that hasnt moved much in the last few years and probably should see the light of day. At one point I had a Nismo 1.5 centre put in the rear diff. It is a clunky nightmare POS of a thing on a good day. To make it less painful the initial torque setting has been put on the minimum (7.0kgf-m, mid is 9.5, high is 14) and the oil changed out to something more slippery. But it is still awful and ruins the vibe of the thing. So my questions are: Given I have the original parts sitting in a box somewhere would it be better to rebuild the thing again, reverting to more purity? Is there a standard kit or do you just go and replace the friction plates etc and shim it the way you like it. How much initial torque does the standard R32 rear diff have? Or does the Nismo disc kit offer a better solution - the caveat being the initial torque for both options appears to be higher than the clunky 1.5 way. There appear to be two Nismo disc kits: 3843S-RS520 for 8kgf-m. 3843S-RS521 for 12kgf-m. Or is the easiest solution to reshim the Nismo diff to make it looser?
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
