Oem Parts...a Great Resource Here
Speedah
 Share
After a small bingle (24kmh impact) with the tyre barrier at Wakefield a few weeks ago (I wasn't driving) Ive been on the lookout for parts to repair the front of my GTR.
This is a great website to find every part and the pricing for it.
http://www.shiftniss...ription=Keyword
Eric at Boulder Nissan has been great to deal with.
The prices are even better when you bundle a heap of parts together
The parts are less than 1/2 of what Nissan Australia want.
I have ordered a complete 2012 bumper/lower lip/LEDs etc
heres a good example...
Nissan AU want $3600 + GST for the front bumper.
And Nissan AU has virually nothing in stock 6-8 week wait from Japan
Edited by Speedah
US prices being lower than AUS is nothing new - just look at car prices for eg;
courtesyparts.com does the online parts thing too and will give you a shipping price on checkout
but what kills you on larger items is the shipping and customs + gst once landed
Edited by domino_z
We are a great resource too Speedah!
Really happy to see you making it bigger and better. We know the pain of a GTR accident, but we also know the whole 'Phoenix' thing and have great belief your GTR will be more of a unit that it was prior to the little tap it had :)
Eric at Boulder is a great guy and a good customer of ours. Seb (Slip35) went and visited him when there the other day.
 Share
    • Well I had 2 choices from then on. I either had to (reluctantly) move it on to another potential buyer and take the loss on the chin. Or I stick with it and turn it into a restoration project. I chose the latter. Project Snowstorm began! The frp body kit was the first thing to go. Turns out the original colour used to be silver. The Neo and gearbox were removed, along with the prop and exhaust system before it took a trip to the bodyshop, where I wouldn’t see it again for quite some time due to the pandemic hitting very soon after they took it away. Eventually, progress began and damage assessments made. Even the front chassis leg was in pretty bad shape!     Then the chopping commenced. For these guys it was just usual routine, to me it looked absolutely terrifying!   More to follow as I’m struggling to focus on my screen at 12:45 am!!!
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
