  • Replies 142
  On 22/07/2012 at 8:16 AM, Hot33r8723 said:
On a rb26 the airflow meters are before the turbos mate senses the air
Flowing through the front of each turbo and signals is sent back to the ecu telling the ecu how
Much air is flowing into each turbo and each 3 cylinders I work for tony rigioly mate
  On 22/07/2012 at 8:23 AM, Hot33r8723 said:
I'm over it mate stuff it I've had enough now
Tony rigoili aye. Didnt know they hired rappers.
  On 22/07/2012 at 8:17 AM, 89CAL said:
Both turbo's end up flowing air to the one point. There is one intake manifold that joins all 6 cylinders
  On 22/07/2012 at 8:19 AM, Hot33r8723 said:
Who gives a crap each airflow control 3 each full stop
Mind blown?
doesn't matter if you rap play guitair listen to techno that has nothing to do with your work status mr pinky and your friend brain
  On 22/07/2012 at 8:38 AM, Hot33r8723 said:
Oh no the one how was smart read the thread there silly bro 02 can cause a lean why cruising which is what I was doing when she cooked her self ahahahaha shutdown NASA scientist
NASA dont take rappers
And skylines don't take idiots like
Yourself and your shut down now so u can't talk my little NASA bathroom cleaner you work for NASA but are hired to clean the toilets ahahaha
Edited by Hot33r8723
  On 22/07/2012 at 8:50 AM, Hot33r8723 said:
Yeah yeah we hear us why so serious hahaha u look like a spastic retarted clown lmao more
Like why so delirious cos u don't no what ya on about ha!
Ummmm, thats Hugh Jackman as the joker.
Its ok, I understand, you cant interpret pictures with a iq below 30
Maybe if I put a afm on him then it might click
  On 22/07/2012 at 9:02 AM, Hot33r8723 said:
Hey man u where shutdown why u still talking trying To Build Up your confidence lol its ok mate
Wut?! :blink:
  On 22/07/2012 at 8:55 AM, Hot33r8723 said:
Haha what is your ride my friend rb26 or rb20 ?
Is this a shutdown?
haha, Im having fun, keep coming at me with all your brain power
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
