Hey guys,
Finding that when changing gears its not as smooth as any other skyline I have driven.
As I put the car into the gear and clutch out the car does 2-3 small jerks as I start to accelerate.
First thing I did when this happened was adjusted my TPS (correct voltage) thinking it had something to do with the throttle. This has not fixed the issue.
So secondly I have also changed the oil in the diff to something around the 90 mark.
I did notice there was a fair build up of metal shavings and my diff oil had a very gold shine to it.
Opinions?
Does the jerking when changing gears sound like a diff issue or something else
https://www.sau.com.au/forums/topic/404864-symptoms-of-a-broken-diff/
If the diff was broken, you'd hear it.
If it's worn - then well, that's almost a given. It's 15 years old :)
Jerking could be a bit of play/blacklash. The mounts could also be quite work. Joints and overall drive train
So the symptoms seem like those of a worn diff?
From what I could find on here and online it only gave symptoms of a broken diff such as loud noises etc.
Mine makes a clunk when I clutch in while it's in reverse. Still trying to work out if the clunk is from the gearbox or diff.
question, how smooth are your gear changes normally and have you got your issues that you were having with your clutch sorted?
Clutch should be coming out this weekend for a new spigot bush and thrust bearing.
That should get rid of the annoying sqeaking noise from the thrust bearing
The issue started after the tune.
But it wouldnt be anything to do with the tune I wouldnt think.
Maybe just the extra power has done something or the change in clutch
Mine does it a bit too, i think its play in the diff, it needs shimming, Im gonna ask Diff Dr.
Does yours sort of slap back and forth when not clutching properly?
How about humming at high speed? Mine does.
gbox mounts?
diff mounts?
rear subframe bushes?
Hes asking if anything is loose, like where the diff bolts on to the car, easier to fix than a diff centre.
You can get a good suspension place to check most of that.
I just had mine all done so its not that.
If your diff is like mine ill keep you posted about what Diff Dr says.
Rang him but he was busy, he said something like "cant shim it, put racing centre in"
I wonder what a "racing centre" is (lsd?) and how much it costs. ill find out later.
I found chunks in the black sludge on my drain plug, so its not going to last too much longer.
Most aftermarket centres are about $800-$1600, i dunno if its worth getting a used one or rebuilding mine. If it can be rebuilt.
Hopefully Rob(Diff Dr) has a solution thats cheap and awesomely strong(clever guy), hes done it before.(my r32 driveshaft, the kingswood diff)
Does anyone know if they can be rebuilt?
Hey guys,
Shimming tightens the LSD up and is nothing to do with the backlash, the diffs would need to be adjusted to take up the slack, if you dont know what you are doing just take the centre to a diff guru :)
If i was in Canberra i would help but 4hrs is a bit far for a quick look!
He is referring to a mechanical diff centre i would say, a lot of fun but they do clunk and carry on in carparks as they are basically locked anyway....
You should be able to check the diff bushes, subframe, tailshaft, gearbox and engine mounts etc man...... Its hard to picture what is happening from your description though......
Yeah all my mounts and things are good, solid mounts, engine damper etc just been done, driveshaft is a new one piece with big unis.
When im under the car (on stands) with the handbrake on and in neutral, the axles are locked from the handbrake, but the driveshaft still has play, but stiff play, if you know what i mean?
I know you can shim the lsd clutches, but In the kingswood he shimmed the gears back in position (no lsd) ill ask him what the go is with this.
Not keen on a crappy centre, though ill see how many $$$.
Thanks Mat.
Edited by D.I.Y. Mik
It's a little hard to explain the feeling in words which sucks. But year it just seems slack much like i don't know a ripple effect when you change gears.
You clutch out and it feels like it rocks into place.
Back lash I guess.
Hope the diff dr can work something out for a good price and go from there. Mine steps out to the left or right when it loses traction so does that mean I guess it doesn't need shimming
You can't shim the standard diff anyway.
You CAN shim it, but what you are doing is not shimming anything that is supposed to be shimmed. Just jamming the internals together hard and wearing surfaces that were not meant to be worn.
Whoever came up with the idea is a retard.
Depends which gears i guess.
The old holden v8 diffs must have big gears and room to do it, cos it worked well for ages,
its not suprising cos they are simple and big.
I know squat about LSDs, and he didnt tell me jack yet so.... monday, Dan i guess ill find out what he can do.
What are you talking about GTSBoy, shimming the gears or the clutches?
I like to know which ideas are crap so i dont get burned.
Anyway its definately rooted, sounds worse after an oil change.
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
