Favorite R33 Front Bar
Hey all
Jus interested in people's opinions on r33 front bars
Ive got a 95 r33 gtst n im looking for a new front bar just seeing what others like n dislike
I kno at the end of the day its what I like not what others like
Jus curious on what others think
Cheers michael 
Edited by FR33ZN
Depending on the style your going for, either the Top Secret or BN sports.
BN needs a lot of work to pull it off though. The perfect offset, right stance, right height etc. otherwise it's a massive fail whale if you ask me!
Currently I'm running a GTR replica kit though!
  • 3 years later...
Sorry to be "that guy" that brings up a super old thread, but I found this on my google searches. What front bar is this? It's incredibruu
Edited by Mandi
I may be wrong but I believe it's a 40th Anniversary optional bar... may be wrong tho
EDIT: Correct I be
http://www.sau.com.au/forums/topic/373439-r33-gts-t-spec-ii-what-front-bumper-is-this/
Edited by kingtube69
EDIT: Correct I be
Thanks so much :)
So basically the first bar I find after searching for some time that I really like and it's uber rare haha fml
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
