Hey guys/gals,
My original right hand side (looking at the bar straight on), black front bar grill (with the drilled dots) flew away on boost.
The front bar is an original, 1999-V Spec front bar (NOT a Z-Tune/GT/Aftermarket front bar)
I am looking to see if anyone possess or has a "spare" one that they will like to sell.
Also, if anyone is aware where to purchase this, that would be tops!
Thanks.
faiz-
Picture of what Im after:
Edited by fujin
