as some of you may know I'm doing a build on my R33 GTS25T 2 door.
currently just a bare engine in the bay atm so ive purchased many parts.
today i recieved my inlet manifold i bought off ebay.
slide industries is the company i purchased from, owned by drifter Ryan Cummings
from what I understand they get them from china and do a thorough inspection of the product.
First impressions unboxing.
Good packaging, everything covered.
overall inspection, good design, good quality, no gaps no casting out of place. inside is really clean and smooth but I highly recommend you always give a thorough clean to any cast products you plan on running.
all the galleries line up, came with all fittings. only thing missing was a throttle body gasket, got some gasket paper and sealant to do the job.
Only got a couple of pictures as I wont be instaling it until my oil filter relocation kit and oil cooler get fitted.
Rough test fit
going to need a new washer bottle, pretty sure ill use an R34 one.
Edited by Crazy Xav
more or less fitment wise, i was expecting to have to get it machine out to line up with the ports on the the head. but did some fitment tests and all lines up so should flow reasonably well.
I will definitely get the face machined as a safeguard. I dont expect any performance increase what so ever. more of a convenience thing (less piping & easier to work on)
Looks fairly simple to install also, but for reference here is what ill be going by.
http://www.skylinesaustralia.com/forums/topic/181826-how-to-greddy-style-plenum-install/page__hl__plenum
Upon removing old inlet manifold (hours and many swears later) one of the heater hoses broke, which happened to be the only non nissan hose, definitely using all nissan genuine hoses.
may paint it black if it shouts "defect me" lol.
you will find its the oposite, everything on the intake side of the engine (under the intake) is now harder to get to and work on. i have and have had the greddy intake for years, prepare to swear at the car any time you need to do something under there.
Damn! lol. i swear enough at this car as it is.
was an absolute b*#ch to remove the standard one, as the car had the cruise control module and alarm siren right next to the inlet manifold.
they have been moved (cruise removed) and oil filter relocation going on as it was already a big job gettng to the oil flter without covering everything.
Have you ever had to do a starter motor with the GReddy fitted?
Makes changing spark plugs a breeze :D did you go with the stock size throttle body, or a bigger size? From what I understand, no real performance benefit with either fhe bigger TB.. Just a more touchy throttle feel, and the ability to flow more air, with less of a pressure drop, and a drop in temp.
Going off the venturi effect anyway :D
from what ive read it can make throttle response doughy down low but improve mid-high range?
It came with a 80mm throttle body. being aftermarket there is no where for tps sensor? hopefully this wont effect much as I'll be using a wolf ecu.
Paid $700 for the kit, there is a fair few cheaper ones, but you have to source nipples and hoses.
Yeah its just a b!+ch to do! that top bolt.. so many grazes and my neighbours asking me to stop yelling lol.
Yeah ive read you loose a fair bit of mid range. Pretty annoyed i have to cut a hole under the washer bottle, as it already has a FMIC and the hole has been cut to the side. But its all a learning experience i guess.
You could try putting in a machined spacer plate between the plenum and head. Ive read of guys thinking this could counter-act some of the loss in midrange. Are you running e85?
Going from 98 to e85, personally I think the difference in midrange wont be overly felt, as the fruit juice would bring up the midrange anyway.
As for the throttle being doughy down low, there is a bit of a misconception about this.. You have to remember that with the bigger throttle body, each degree of movement compared to the stock item, is actually opening a larger area = more air for a given movement = more power due to more combustion = a very touchy throttle.
Turbo size, etc, also plays a big part.
Ive also heard of the spacer idea, as the longer runners on the standard item are what make it so balanced. not sure if ill be going E85 yet, going to be mainly street driven and tbh going from a standard tune to whatever the end result is ill be happy.
The turbo is a Hypergear ATR43. G2.5 profile. unsure of exact specs. Thankyou to everyone who suggested I get one of these turbos :D
Check the flange with a straight edge and pressure test before fitting. Buy or make an adapter and use your stock throttle body and TPS (sell the 80mm one to get a few $$ back).
I wonder if there is anyway possible to avoid cutting a new hole and reusing the hole previously cut, I am also thinking of moving to an aftermarket plenum (purely because I want to lol).
It seems there is enough room to run a 45 degree silicon pipe then straight down and back into the existing cut hole.
Does anyone have a photo?
    • Hi guys my 94 r33 gtst fuel pump has gone out. I have a walbro 525 ready to go in but am unsure if I need to upgrade the fuel tank bulk heads? Ive heard that others have issues with the stock wiring melting... Ive seen alot of people recommend this: https://frenchysperformancegarage.com/products/fpg-nissan-skyline-r33-r34-silvia-s14-s15-billet-fuel-tank-bulkhead-hat-top-an6-with-high-current-connector-apex-2-8-delphi-fpg-100?variant=42873255198898 My current pump that stopped working is aftermarket but I had no relay mod or upgraded connectors. Need some advice please. TIA
    • It’s new. It’s the cd009. I did take the transmission apart to mill down the bellhousing and had both housings come off the gears so wondering is something isn’t in right. I am running redline. I can get it in gear running too but it’s just not easier and it’s almost like 2, 4, 6, and reverse all the back gears aren’t happy going in
    • I’ll remember that as a last choice. It’s brand new
    • Got keys and did a walk around the yard planning the landscaping works with the family that I will be doing Main effort: remove all the woodchip in the gardens that are around (attached) to the outside of the house and replace with 10mm blue metal, having woodchip close to the house is a recipe for inviting white ants, currently there are no white ants within the block and I would like to keep it that way I'll be buying some large raised garden beds to grow veggies and stuff, and the woodchip will be mulched with everything else that gets dug up, pulled out, or cut down during works Next will some minor drainage and landscaping maintenance up one side of the house, where the fuse box, AC, and solar stuff will go, about 12 mtrs long by 2 meters wide, I'll break up the soil, add gypsum and then I'll dig in a French drains about 300mm deep x 300mm wide and fill it with agg pipe and blue metal, then level out the whole area with a 50mm layer of blue metal, the soil, whilst currently pretty compacted, will break up well with the gypsum to aid in drainage, I'll then cover the area with a 50mm layer of more blue metal In saying this, the drainage issue is minor, but that little hidden away area down the side is untidy and weedy, and as all of the main elec stuff is there I want it neat and tidy to appease my OCD Again, the material excavated from the French drains with be added to the garden bed mulch, as will some rose bushes and some other crap looking garden plants, and a old apricot tree that is looking worse for wear The apricot tree is currently in a little roundish garden bed that is in the middle of the back yard with few other crappy looking plants around it, that will all be removed, levelled, re-turfed, and is a perfect spot for a hills hoist There is also a area about 3m x 2m between the rear fence and shed that will get some attention, it looks like some stuff was stored there and the grass is dead, that will also get broken up and mulched, and is a prime spot for a pumpkin patch I've guestimated that I'll need: 3 tonnes of blue metal, 12 meters of agg pipe, 5kg of Gypsum, and a hills hoist, so a few bags of concrete as well to set it in place (the house currently has one of those pull out 4 line jobs, whilst it works, I want a retro old school hills hoist), I am also going to run some chickens, there's a great spot for a coop, so a chicken coop to suit 4 of those lovely egg laying bitches will also be on the job card That should keep me busy for a while, and will finish off the back yard ready for a early spring planting of some veggies and berries  Once the main effort is done I'll start out the front, there's a large rock garden that could use some TLC, but that is only minor works Should be fully moved in within 2 weeks, the landscaping works will start then Fun times, retirement is good
    • It happens, that's what your single stage filler is used for.  If it is still visible after the 3 coats of 2k primer, it will be visible after the paint is laid down.  Its hard to give 100% perfect advice without being there in person, I'm very tempted to say stop where you are, fill your pin holes with a single stage putty first then keep going.
