Word.
R33GTS-t
Say for a setup which consists of a frount mount intercooler, full 3 inch exhaust, cold air intake, standard turbo at 12psi what would be the expected increase of a Power FC over a S.A.F.C. fitted to this setup ?
And same question on the same system with a standard turbo high flowed for 16psi ?
I know one benefit would be the removal of the speed/boost restrictors....but I'm interested if there is a major gain between the fitting of a S.A.F.C. over a Power FC
ANDREW
https://www.sau.com.au/forums/topic/4049-safc-or-power-fc/
At 12psi I'd say there would'nt be hardly any benefit in the extra money for the Power FC, however with a large turbo @16psi there would be, considering you may need a Z32 AFM and injectors to safely keep it in tune. It all depends on what power you want for eg. the stock injectors and AFM are good for 210-220rwkw so I'm told. As a guide FMIC,exhaust,SAFC,fuel pump and stock turbo@12psi achieved 188rwkw for my car.
https://www.sau.com.au/forums/topic/4049-safc-or-power-fc/#findComment-65289
You've seen the results shown around here haven't you? Someone got 45rwhp from a tuned SAFC. That really is quite a fair bit, so if you aren't sure I'd just go with a SAFC. It's just cheaper and provides the bulk of the power that the PowerFC gives you.
That said, I'd say the Power FC would probably give you that little bit extra to take you over the 200rwkw mark at 12psi if I use turbomad's and other ppl like Ethan's results as a guide. I have a SAFC which is untuned at the moment, but I'll probably post a thread with my dyno results when I do get it tuned.
https://www.sau.com.au/forums/topic/4049-safc-or-power-fc/#findComment-65457
Sorry if I am hijacking the thread here dude...
Surely there are other concerns other than power when choosing between a PowerFC and the SAFC?
One big one for me would be throttle response and drivability - surely the PowerFC is going to give you sharper mapping of the timing, ignition, fuel and boost in a coordinated way to make the overall driving experience more fun (and give a few more kw)?
If you were to start from scratch (like I am with a freshly imported R33 GTST), wouldnt the PowerFC and the boost control module be a better choice than a SAFC and separate boost controller?
I have used bleed valves before on my WRX, and they were awful - boost would bleed away at the top end when you want it... an EBC totally changed the power curve of the car so I dont think I would be happy with that to go with a SAFC.
So that means the SAFC with AVC-R (I think thats the Apexi boost controller?) vs the PowerFC and boost module is the comparison.
The SAFC/AVC-R setup is a little cheaper, but surely you lose crispness in power delivery and some Kw as you cant adjust timing (or am I incorrect??).
I had a Unichip and once they leaned up the fuel AND advanced the timing appropriately the WRX was so much crisper and responsive to drive it felt like a different car... just my 2cents.
Conrad
https://www.sau.com.au/forums/topic/4049-safc-or-power-fc/#findComment-66084
Conrad
the boost control option on the PFC is crap, yes it does the job but no where as good as the AVCR.
the SAFC does the fuel side and allows manual advanment of the timing. while the PFC controls the fuel and timing and has more tuning points.
drivability isn't that different, but they main guide i'd go with is if you plab on upgrading the turbo in the future. if so go the PFC as the safc just want cut the mustard once the stock injectors reach 100% duty cycle.
to answer Andrews (peakRPM) question the PFC would give a better power return due to it controlling both fuel and timing and having more mapping points.It would also allow you to do further mods more easily in the future such as bigger injectors, turbo etc.
https://www.sau.com.au/forums/topic/4049-safc-or-power-fc/#findComment-66093
skyzer33, can you give me some more info on your points?
Why is the boost control on the PFC crap, whats wrong with it?
And what do you mean 'manual advancement' of the timing?
Do you mean by change the AFM signal it inadvertantly causes some level of timing change, or does it actually have timing maps? I checked the website and it doesnt really talk about anything other than fuel mapping...
So what would you recommend - using a SAFC and an AVC-R together? I guess if its cheaper and easy to map than the PFC it would be an ok option as I dont plan on replacing the turbo with a different one (unless it lets go then I might jump up to something larger.. maybe).
Thanks for the info, I am still getting up to speed on this gear for the R33 - the WRX was great with a Unichip and boost module, but obviously the skyline is a different beast (and I really hate the self learning dribble with the factory ecu's part of my reasoning for wanting a replacement ecu rather than an intercept unit).
Ta
Conrad
https://www.sau.com.au/forums/topic/4049-safc-or-power-fc/#findComment-66687
If you don't plan on replacing the turbo then go the SAFC. Remember if you go a large turbo you may have to change injectors and AFM which in turn will demand the fitment of the Power FC, it kind of snowballs in price at this stage. This is where I am at the moment, I'm looking for a suitable turbo that will run my injectors and AFM and ECU/SAFC to the max and if I can make 210rwkw then that's what I'll have to be happy with.
https://www.sau.com.au/forums/topic/4049-safc-or-power-fc/#findComment-66739
Can someone clarify what level of control over ignition timing the SAFC provides? I thought it purely controlled the AFM voltage level in an intercept function to trick the sotck ecu, so you are finitely limited by the fuel maps of the stock ecu and have to deal with the ecu 'learning', and potentially retarding the timing if detonation occurs.
I guess if the SAFC CAN do ignition timing I will look at it..
Ta
Conrad
https://www.sau.com.au/forums/topic/4049-safc-or-power-fc/#findComment-66832
slayer
the safc tricks the ecu into thinking ur running stock fuel ratios which allows you to advance the timing without the ecu retarding it thats what i meant by manually adjusting the timing.
why the PFC boost add on is crap. it does its job well but there are some issues with it at higher boost levels. Plus the AVCR is better more features and has fuzzy logic.
https://www.sau.com.au/forums/topic/4049-safc-or-power-fc/#findComment-66866
the dyno charts of my car after install of PowerFC WITHOUT tuning jumped about 25rwhp...
After tuning saw more like 45rwhp.
At 12psi (controlled by Blitz Dual SBC), it turns 271.3hp/202kw @ rears.
Will post the dyno chart if i get a chance. Stock, plug-in, tune, re-tune are all on the same graph.
Cheers
https://www.sau.com.au/forums/topic/4049-safc-or-power-fc/#findComment-66936
Power FC is the way to go, why half do it with an SAFC?
The gains and tuning ability of the power FC make it the better choice especially with the price you can pick them up for second hand these days.....
plug and play
https://www.sau.com.au/forums/topic/4049-safc-or-power-fc/#findComment-66951
Slayer - The SAFC cannot do ignition control... That's why it's just a SAFC... IF you want ignition control then you'll have to get the ITC.
As someone who's used both (SAFC & Powerfc, (and even unichip)), I can tell you from experience that if you can afford to spend the extra $$$ you fork out for the powerfc is definitely worth it.
That being said, there's nothing wrong with the SAFC for a lightly tuned car with the standard injectors, just beware that it is an interceptor, and doesn't alter the overall tune, it effectively just alters the voltage the ecu see's that the AFM is sending it.
Oh - and the best feature of the powerfc, is you can tell if your car is pinging!
matt
Ta
Conrad
https://www.sau.com.au/forums/topic/4049-safc-or-power-fc/#findComment-67031
LOL - while I'm happy to tell you, my motor doesn't bear much resemblence to an RB25 anymore :D In any case... Most it'll usually go to is between 20-30 @ wot, with the occasional spike to 50, which is usually when I come off the throttle.
When I had my '25, it was about the same...
matt
Originally posted by 2rismo
Out of interest, mate, what does your knock readout go to on different types of fuel, fuel + octane booster etc...
Just interested.
Cheers.
https://www.sau.com.au/forums/topic/4049-safc-or-power-fc/#findComment-67186
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
    • We have an alignment shop out here that does what you're talking about but he wants like 800 AUD a pop. DIY is "cheaper" but once you start accounting for the value of your time I'm not sure it's worth it.
    • The main catch phrase for any car is "the eye of the beholder", and "personal tastes and preferences" And as for the plastic "flares", I honestly think they look cheap and tacky, and I cannot see them aging well, maybe if they were body colour they might look better to my eyes, but, I would still prefer it the were more like the older WRX STI models that had the wider body metal panels In saying all this 5hit, I wouldn't buy a new WRX again, even if it had the wide body metal panels
