  • 3 months later...
i just tried a set of Winmax Sport pads from BEL Garage recently. Works very well on track, with no fade in ~ 10 laps of late braking. very quiet on the street, no squeel at all (except right after a trackday, but that's normal performance pads, and even then, only for a day). highly recommended.. they only lose out to comparable Endless SSS, etc pads in initial pedal feel when cold with light braking. less than half the price of Endless / Project Mu tho, so very good value.
Thanks for your post. Might explain why the Winmax pads are so popular. If they stop the noise they will be worth every cent!
  • 4 months later...
I think this thread needs updating. A track day fixed mine for good but now I've got new pads on (bendix ultimates again) the squeal is back and worse. New slotted rotors at the same time.
I'm just trying to understand Sydneykids post a bit here. The pads came chamfered straight out of the box...
Right... down to the garage I go.
I guess he thought they might not be chamfered out of the box. I fixed my prob with Ferodo 2500 pads and DBA 5000 discs, which were shrieking at pain threshold dbas, by going to solid discs...silent...Tried Lucas organics and the 5000s on and the squeal came back but at about 1/10th volume. Of course the performance of the 2500s is gone, too. You could try Mintex stick on shims, it might help a bit.
I'm still waiting for a set of Winmax pads from Bel. Reminds me I must email them and see if they will ever come in.
My car is off the road at present with some radiator/oil cooler changes but soon to be finished and then I'll get back on the case.
Any suggestions greatly appreciated.
regards
Andrew :headspin:
  • 1 month later...
I have been just bitten by this problem after a r32 brake upgrade. dba400 r33 gtst calipers. I have noticed that if it gets really bad I need to stick it in reverse. This seems to fix it for a little bit. Damn if racebrakes rb74's are "low dust, low noise". 10 k's after the upgrade rims are black and complaining like a girl. I guess every 10k's we need to jam it in revese.
Funny, my setup with Comp 9's on the front with R33 calipers squeal like all hell, but the same pads on a mates R33, dont make any noise at all.....doesn't make sense
I think finding a cure for brake noise is hard, because everyone's cars a differant and experience differant driving conditons and temperatures, but if anyone finds a fix, let me know :P
Chris
I notice my EBC Red Stuff Ceramics have a ruberised shim molded to the pad... maybe the stuff they are using these days means you cant just throw your shims away.
The shims are just soft metal to dampen the high frequency vibration.
Slip the pads out, use as a template to cut a shim from a can that had your fav drop in. This will stop it if it can be stopped...
Also there should be an anti rattle clip on the back of the caliper.
Hope this helps
TT
Could you tell me more about the anti rattle clip please. Is this on the back of the caliper and how do I recognise it, or is it a kind of corner shim which goes on the corner of the actual pad plate which is what I think you mean?
Either way what should I tell the brakes shop to get this clip?
Thanks
edit...
thought I should ask whether your EBC RED Ceramics squeal or not?
The clip is on the outer radius of the caliper. It is held in place by the two long steel pins ~ 5mm diam that go through the outer radius from side to side and are held in with cotter pins. The clip sits under the pins and is squeezed against the outer edge of the pad backing plates. It's no different to the standard ones other than the shape. Re a previous thread I don't think that Brembo make anti squeal shims. Mintex make universal stick on ones. As per my previous thread changing from 5000 to 4000 discs cured the squeal with Ferodo 2500 pads and no shims. Quiet as a church mouse.
Show it to a brake shop, they'll tell you if you have them or not.
As I am sure everybody in this tread is like me and is sick and tired of the brake squeal problem. I encountered this problem when I recently upgraded my r32 gts-t hardware to r33 gts-t hardware with racebrakes RB74, and DBA 4000 rotors. Every where I called said that it was normal for this brake setup to make “some noise”, some noise? For the people with the really bad squeals I feel for you as I had a really bad one too (about 95dB, and that’s a little noise). Now I decided to take things into my own hands to find that my problem was fixable. As chris32 has said everybody has a different setup and has the squeal for different reasons. If you want to fix this problem you have to understand it first. Jack the car up and undo 4 bolts, 2 clips and 2 screw type things, and have a look. What we need to do here is find some remedies to common problems.
- Have a look at the rotors are they really shinny (glassed), machine them.
- Is there dark spots on the rotors (heat spots) machine them.
- Is there cracks on the rotors (replace them)
- Have a look at the pad surface are they smooth (sand paper them, or replace)
- Are the pads worn unevenly (i.e. only some of the pistons working. rebuild)
- Are the pads gone (there sometimes is a metal wear indicator) replace
- Are the four shims in place (two solid, two with groves, if not put them in)
- Have you got some lubricant between the shims and the pads ($12 from super cheap)
- I am sure there are more that people can add
Now the first thing you will notice when you put a wheel brace near the rims is that they chime like bells. This is the reason why the squeal like a pig if there is any reason for them to. Once you have had a look report back to the forum with fixes and the hardware you have.
Car: r32 gts-t 4door
Rotors: dba 4963
Capilers: r33 gts-t stamped nissan
Pads: Racebrakes RB74
Problem: very very loud near stoped (>40km/h)
Fix: Installed the four shims that the shop took out, added dyna grip disc brake squeal free
Results: pedal seems the same if anything it is a little firmer, but same pressure results in a minor reduction in brakeing force (barely noticable). No noise
