This model one of the last R33's ever made, released in March, 1998!
1998 Series 2 M-Spec R33 Skyline GTS-T
128,000 kms
Rego till May 2013
Engine:
RB25DET
Haltech Platinum Pro 1000 ECU
Garrett GT3076R turbo (0.82 rear housing)
Braided turbo lines
Custom High Mount T3 Manifold
Tial 44mm External Wastegate
Custom Screamer Pipe
Blitz 880cc Injectors
Blitz Aluminium Radiator
Blitz Turnflow Front Mount Intercooler (painted black)
Walbro Fuel Pump
Spitfire Coil Packs
Clear engine cam cover
JJR exhaust cam gear
HPI Pod Filter
JJR Front Strut Brace
Custom 3" turboback exhaust system with XForce muffler.
Wheels:
Varrstoen 2.2.1
Front: 18x9.5 +12 (225/40/18 tyres)
Rear: 18x10.5 +12 (235/40/18 tyres)
BLOX Racing 60mm Extended Wheel Nuts
Drivetrain:
Exedy Single Plate Clutch
Nismo lightened flywheel
Nismo gearbox mounts
R33 GTR diff
R33 GTR driveshafts
Suspension:
JJR Hicas lock bar
JJR Adjustable rear camber arms
JJR Adjustable front camber arms
JJR Adjustable castor arms
Top Secret/Aragosta 3-way fully adjustable coilovers
Exterior:
Full Explosion bodykit
Stealth lip wing
5% tints all round
Slimline window visors
Carbon B pillar trims.
Interior:
R33 GTR Seats
4 point half cage with padding
Nismo dash cluster (goes up to 300kph)
Autometer boost gauge
Blitz TurboTimer
Nismo floor mats
Nismo gear knob
Fire Extinguisher
Clarion VRX486VD DVD Headunit
Kenwood Amp
Apline Type S 10" Subwoofer
Car makes 306rwkw on 16psi (have dyno papers to prove)
The car is fully engineered, with engineers papers in the car and also with the RTA. Buy this and never get defected!
After 15K ono.
I am very negotiable on the price, so make me an offer.
Will swap for a Mazda 6 MPS.
May swap for other cars, depending on what it is.
Here's a pic for now, will take some better ones and upload later. Contact me on 0468 714 685.
Edited by Stunn-R
how long has it been running at 306rwkw and how often does it get thrashed??
dont bother saying it doesnt get thrashed , with 306rwkw you know your gonna boot it anychance you get lol :P
Its been running that power for over a year
I've recently got the tune checked out and its running perfectly,
I've owned the car for 2 months and haven't really thrashed it at all, yes occasional hits on the street but thats it (anyone that knows me can vouch that I baby all my cars)
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
