At the moment i'm on 86,000KM on my V35, i was curious if anyone has got their 100 thou service done through Nissan before and how much did it cost you? I'm considering sourcing all the parts i need and only paying for labour but has anyone actually left the entire service for Nissan or someone else to do? Just thought i'd get prepared for the big service although my car seems to be running fine.
Cheers
https://www.sau.com.au/forums/topic/404908-100000-v-service/
find a reputable mechanic to do it. Nissan will rip you off big time no matter which way you look at it and I doubt they will allow you to supply parts as this will no doubt void any warranty on "their" service.
Yeah figured that Nissans good at doing that aren't they.
what are you expecting to change at the 100k kms service?
Well i've just replaced my belt that controls air con alternator battery etc and clutch/brake fluid so basically anything else that needs doing. I don't have much of an idea as to what needs doing that can be called "major" though.
86,000 K's? I think your odometer may have had it's service already. :P
What do you mean? I bought the car at 80,000 and it hadn't been serviced for a while the guy had pretty much done it himself but i don't know what he's done so i'm iffy about it :/
The 100k is generally a term for cars with CamBELTS (not chains). It was always the old interval to change them. In recent years on newer cars, some manufacturers will go to 150k kms on a cam belt or X years.
Since you don't have a cam belt to change there is really nothing out of the ordinary about a 100k kms service.
When servicing, its a combination of -
Engine oil and filter
Air filter
Brake fluid / bleed
gearbox/transmission oil/ fluid
Differential fluid
Engine coolant
Brake pads and discs as required
interior / cabin air filter
Ancillary belts as required
Spark plugs are 100k km items
in tank Fuel filter
anything else I forgot
If you don't know when last done or have no record then its a good idea to change and record it.
I did mine last week,all fluids and filters, spark plugs, new pads. I bought all the parts before I had the car in, cost me $500 in labour but that's also including installing a plenum spacer lol. My mechanic is also a friend of mine so I don't mind paying a little extra for the peace of mind knowing everything is done the way i want it while chatting with him when he's working on the car. If you car is an Auto you MUST only use OEM Nissan transmission oil (Matic J) and if you are unsure when your trans oil was last serviced I wouldn't recommend flushing it IMO. I'm not too sure on the coolant whether it has to be the OEM antifreeze, but i used that just to make sure...maybe someone can clarify this.
Thanks for that Alex, good to know nothing major needs to be done. I can basically do all of that from my garage.
Kevin, i have a manual but yes that is good for you! too bad there are no reputible mechanics in my town :/
Nulon synthetic trans fluid is fine, just don't use dextron III, it will slip and ruin your clutch plates. Back flushing is a good idea, as is dropping the pan and cleaning the filter if you are keen.
Mixing antifreeze is a bad idea, but who knows what is in your cooling system now... I would flush it a few times with water and drain it completely, (the block drain plug is a pain to get to) then refill with a decent off the shelf coolant.
i've noticed with the auto-trans fluid. i used one of the nulon trans fluids on my previous change after i first took delivery of the car, after that the changes semmed a bit jerky to me. but after replacing it with the matic-j. its alot smoother than its ever been.
mabye its just me. but i'd stick to the genuine nissan stuff.
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
    • All clamps are oem    one question is , what is the bit at the top on high pressure pipe where it connectes to intake manifold and other side goes toward the engine( see item in red circle in diabram attached)   ? Seen some people stating that should be removed on boosted application and skyline is boosted from manufacture so little puzzled. Mine is around 23pwi (700 hpish)   also some state it could be the bonjo bolt crash washer so bought two washers
    • what do you mean dead platform? People buy older, out dated and less power cars on "Dead platforms" for over $65k all the time.
    • That is really nice! Very nice finish when you have an oven to do the crinkling nice and evenly!
