Mcboost Posted May 8, 2004 Share Posted May 8, 2004 hey guys, comming home tonight, my r31 rb20det just cut out as i was changing down gears to take a corner, just went dead. still got fuel pumping and ignition but just wont start, left it for 10 min, tried a few times, then waited another 5 and started up fine!!! WTF???? anyone had this before?? i was thinking faulty ignition or coil packs or maybe just water cause its been a wet night, but wasnt raining very hard!!! Link to comment https://www.sau.com.au/forums/topic/40494-rb20det-just-cut-out-wouldnt-start-why/ Share on other sites More sharing options...
JimX Posted May 9, 2004 Share Posted May 9, 2004 Hang on, you say you still had ignition, but then immediately afterwards you suspect it was faulty ignition? I don't get it :confused: How did you think you were still getting ignition? I mean you can hear the fuel pump if it's working, but unless you had a timing light in your car and tested it while you were cranking it over, I'm not sure how you could be certain that the ignition was still working. It could be a faulty igniter. Link to comment https://www.sau.com.au/forums/topic/40494-rb20det-just-cut-out-wouldnt-start-why/#findComment-831644 Share on other sites More sharing options...
