Hi people,
I tried searching for the -5 Vs -10 thread however I could not find it, this topic may be a little different as the car is running on e85.
Key considerations
- Motor is a fully built Rb 26 (26 bottom end)
- 262 in/ex cams
- Car is built for street/drag
- The car made 420 rwkws on 20 psi, we tried raising the boost however there was no power gain (I believe turbo’s were out of puff)
- Fuel system is more than capable of 500+ kws
My questions are
1. How much laggier would -10s be compared to -5s (running e85 can put more timing into it)
2. Is there an in-between turbo or any other turbo suggestions that will get me up to 500rwks?? (please keep in mind that this is a street car and needs to be low mounts)
Attached is my current dyno graph
Thanks
Daz
  • Replies 70
http://www.skylinesa...age__hl__piggaz
There you go.
Quick answer. If it's a 2.6 don't bother. It will become a nugget.
*Awaits for the can of worms to be opened*
Gav made 460 + on the baby -5's. It's just a matter of setup.
There you go.
Question answered, close thread ;)
For a twin set up chasing that power I wouldn't use -10s, it will just be a laggy peice of crap.. Especially on 2.6.
You probs won't make 500 on -5s but It's probs your best option if you wanna make big power on twin low mounts..
Unless you wanna run a pair of the new GTX turbos.. You should do that :)
Edited by GTR_JOEY
Dan, what's involved in being the test dummy?
Someone is already interested in trying them but I could ask for a second pair maybe. Still waiting for info back to confirm the comp cover is going to fit against the standard manifold
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
